epines Posted February 27, 2024 Share #1 Posted February 27, 2024 Advertisement (gone after registration) Does anyone know of any kind of extension tube that can be used with S lenses? I have the 120mm, but there are times I want to focus closer with other S lenses. The solution I have so far is to use the H adapter with my H lenses, but I'm not sure if the camera communicates with H lenses when the H extension tube is attached. Link to post Share on other sites More sharing options...
Advertisement Posted February 27, 2024 Posted February 27, 2024 Hi epines, Take a look here Extension tube for S lenses? . I'm sure you'll find what you were looking for!
Pieter12 Posted February 27, 2024 Share #2 Posted February 27, 2024 21 minutes ago, epines said: Does anyone know of any kind of extension tube that can be used with S lenses? I have the 120mm, but there are times I want to focus closer with other S lenses. The solution I have so far is to use the H adapter with my H lenses, but I'm not sure if the camera communicates with H lenses when the H extension tube is attached. How do the photos look? Is the metadata there and correct? Link to post Share on other sites More sharing options...
epines Posted February 28, 2024 Author Share #3 Posted February 28, 2024 Just tried it. No go -- the H extension tube doesn't work with the H adapter on the S body. It will shoot wide open, but if you try to stop down the lens, the camera won't capture a shot. Link to post Share on other sites More sharing options...
Photon42 Posted February 28, 2024 Share #4 Posted February 28, 2024 I just checked for you: my S2 with S-Adapter-H, 13mm extension ring H and 100HC orange dot takes photos fully open and stopped down. Even the leaf shutter in the lens works. 1 Link to post Share on other sites More sharing options...
John McMaster Posted February 28, 2024 Share #5 Posted February 28, 2024 Leica do not make any S extension tubes as most/all the lenses have floating lens elements, you would not get the best quality if they are not in the correct location... I use my R 100mm APO with ELPRO (or Mamiya 645 bellows with enlarging lens) if I need greater magnification in camera. john 1 Link to post Share on other sites More sharing options...
davidmknoble Posted February 28, 2024 Share #6 Posted February 28, 2024 +1 on the R APO 100 f/2.8 with Elpro. I also think the Hasselblad CF 120mm does well stopped down, but I prefer that in square crop to remove any issues at the edges. The newer version of the R 100 (not the f/4) is incredible. Link to post Share on other sites More sharing options...
mgrayson3 Posted February 28, 2024 Share #7 Posted February 28, 2024 (edited) Advertisement (gone after registration) The Elpro for the R 100/2.8 works well on the S 120/2.5 and yields a credible 1:1. The only thing you need is a step-down ring. The Elpro for the S 180 is lovely for close, but not macro, images. The Maimiya 645 120/4 Macro is an excellent and inexpensive 1:1 option, even without bellows. Edited February 28, 2024 by mgrayson3 1 Link to post Share on other sites More sharing options...
epines Posted February 28, 2024 Author Share #8 Posted February 28, 2024 Thanks, everyone. Good info here. @Photon42 -- I just tried another lens, and it's working well. Very weird. My HC 50mm II only seems to work wide open with the H extension tube, but my HC 80mm works at all apertures. Link to post Share on other sites More sharing options...
Photon42 Posted February 29, 2024 Share #9 Posted February 29, 2024 The tech specs of Leica's S-Adapter-H list the extension tubes as "not compatible". Don't be too surprised that is may not work in some circumstances. I am more surprised it actually does work in my case. If you own the 120S, I would look into the proposal of @mgrayson3. High quality close-up lenses are often better, because they don't put the lens into a focus distance area it was not designed for. 1 Link to post Share on other sites More sharing options...
