carstenw Posted November 26, 2007 Share #1 Posted November 26, 2007 Advertisement (gone after registration) Due to the diligence of several individuals recently, I have now almost completed the lens code table, including images of the codes. The only lens of which I have no confirmation of the code nor image, is the Leitz (?) 50mm f/2 Summicron III, also known under the purchase number 11817, and it was produced from 1969-1979, with serial numbers 2.269.251-2.915.800. Does anyone have access to a coded copy of this lens? Second question: is there an interest in images of the lenses themselves? I could add a link to each entry with images of the lenses themselves, perhaps easing identification for some? Link to post Share on other sites More sharing options...
Advertisement Posted November 26, 2007 Posted November 26, 2007 Hi carstenw, Take a look here Lens Code Table call for help: 50 Cron III. I'm sure you'll find what you were looking for!
gravastar Posted November 26, 2007 Share #2 Posted November 26, 2007 Due to the diligence of several individuals recently, I have now almost completed the lens code table, including images of the codes. The only lens of which I have no confirmation of the code nor image, is the Leitz (?) 50mm f/2 Summicron III, also known under the purchase number 11817, and it was produced from 1969-1979, with serial numbers 2.269.251-2.915.800. Does anyone have access to a coded copy of this lens? Second question: is there an interest in images of the lenses themselves? I could add a link to each entry with images of the lenses themselves, perhaps easing identification for some? I have two 50mm Summicrons, serial #s 361801x and 251841x. The first is the tabbed version and the second is within your serial number range. I've had the tabbed version coded and I believe the lens heads (which can be unscrewed) for both designs are identical. I was told by Leica UK that the untabbed one could not be coded because no mounts are available for it. The mount is at least 2mm thicker than the tabbed version and the degree of rotation needed to cover the focus range is also very different between the two lenses. The tabbed version has the symmetrical code of B W W W W B. ETA: The tabbed lens is a "Leica" and the earlier untabbed a "Leitz". Bob. Link to post Share on other sites More sharing options...
carstenw Posted November 26, 2007 Author Share #3 Posted November 26, 2007 The one you call tabbed is the 50mm Summicron-M IV, which is the current version. The serial number you state for the second lens is within the range, but perhaps there were mount differences somewhere which didn't require moving to a new order number... Leica does supposedly have a code for it (010111 or WBWBBB ), so perhaps it can be coded after all? An email to Leica would clear that up; Perhaps the dealer wasn't right... Link to post Share on other sites More sharing options...
sean_reid Posted November 26, 2007 Share #4 Posted November 26, 2007 Hi Carsten, Absent evidence to the contrary, I'd recommend that folks just code that as a current 50 Summicron. Coding does very little for 50 mm lenses in any case. Cheers, Sean Link to post Share on other sites More sharing options...
etrigan63 Posted November 27, 2007 Share #5 Posted November 27, 2007 I think Carsten is being thorough, Sean. Link to post Share on other sites More sharing options...
sean_reid Posted November 27, 2007 Share #6 Posted November 27, 2007 I think Carsten is being thorough, Sean. Yes, I know. Link to post Share on other sites More sharing options...
doubice Posted November 27, 2007 Share #7 Posted November 27, 2007 Advertisement (gone after registration) Carsten, Many thanks for the information that you so painstakingly collected. I have used it many times in the past. If I may make a suggestion - right now, you have the lenses sorted in a descending order by 'value'. Most users accessing the list will be looking for a particular lens, to obtain the code. Might it not be better to sort the list by focal length, to make it easier to find a lens one is looking for? Just a thought..... All the best and thanks again, Jan Link to post Share on other sites More sharing options...
carstenw Posted November 27, 2007 Author Share #8 Posted November 27, 2007 Jan, that is a good suggestion. I will switch it around when I get a moment. Link to post Share on other sites More sharing options...
cbretteville Posted November 27, 2007 Share #9 Posted November 27, 2007 Carsten, Yes, images of the lenses is a good idea. - Carl Link to post Share on other sites More sharing options...
papimuzo Posted November 27, 2007 Share #10 Posted November 27, 2007 Yes Carsten, the pictured lens codes are a good idea. I used the table several times (several CV lenses and one 50/1.4 Leitz Lux Leica refused to code). Thanks once more. Link to post Share on other sites More sharing options...
