Olaf_ZG Posted February 13, 2024 Share #1 Posted February 13, 2024 Advertisement (gone after registration) So I went some days abroad, just before leaving i took the SL and mounted the sigma ef adapter and the planar 85mm on it. Didn’t check though. Now switching the camera on, the small top display gives me an error, but doesn’t say which one. The camera still stand it M which might not be supported? the backscreen remains black. I have no other lenses with me. What could this be? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted February 13, 2024 Posted February 13, 2024 Hi Olaf_ZG, Take a look here Error in SL2-s, can someone help?. I'm sure you'll find what you were looking for!
BernardC Posted February 13, 2024 Share #2 Posted February 13, 2024 8 minutes ago, Olaf_ZG said: So I went some days abroad, just before leaving i took the SL and mounted the sigma ef adapter and the planar 85mm on it. Didn’t check though. Now switching the camera on, the small top display gives me an error, but doesn’t say which one. The camera still stand it M which might not be supported? the backscreen remains black. I have no other lenses with me. What could this be? Thanks. The Sigma EF-to-L adapter isn't supported on the SL, only the SL2 and SL2s. You need to use the (discontinued) Novoflex adapter, or a "dumb" adapter, with the SL. Link to post Share on other sites More sharing options...
Olaf_ZG Posted February 13, 2024 Author Share #3 Posted February 13, 2024 To be clear, i do have the 2s, and zeiss lenses worked before. 1 Link to post Share on other sites More sharing options...
DirkZ Posted February 13, 2024 Share #4 Posted February 13, 2024 Is it "System Error"? If so, it could be the shutter. I've had this with my SL2-S. Link to post Share on other sites More sharing options...
Olaf_ZG Posted February 14, 2024 Author Share #5 Posted February 14, 2024 No, it just writes “error” on the top display… Link to post Share on other sites More sharing options...
Olaf_ZG Posted February 17, 2024 Author Share #6 Posted February 17, 2024 Returned home, tried the 24-90, but error remained. My worry grew, as I would hate to have my camera send in for repair. Removed card no. 1, and the camera worked. Put the card back in, no problem at all. So, obviously it had to do with the card: might not have been put correctly. Link to post Share on other sites More sharing options...
davidmknoble Posted February 19, 2024 Share #7 Posted February 19, 2024 Advertisement (gone after registration) Hopefully reformatting the card in a computer first works for you Link to post Share on other sites More sharing options...
Olaf_ZG Posted February 19, 2024 Author Share #8 Posted February 19, 2024 6 hours ago, davidmknoble said: Hopefully reformatting the card in a computer first works for you This is my first time. Till now, I always format in camera, never had any problems. I more assume that I didn’t put the card in as it should, may be it was even locked. I simply took out and put in the card, and that did the trick. Lesson learned for next time. 1 Link to post Share on other sites More sharing options...
