28framelines Posted January 24, 2024 Share #1 Posted January 24, 2024 Advertisement (gone after registration) Hey folks, I have a Godox AD100Pro, and I am wondering what flash trigger I need to use to get it working properly. I tried the X2T trigger I have for Fujifilm, but when I tested it, it flashed twice: once at shutter curtain open and once at close. It seems I may be able to get this to work some other way with a pc sync cable but I don’t know what kind I need or where to actually get one in Canada. Please help! Link to post Share on other sites More sharing options...
Advertisement Posted January 24, 2024 Posted January 24, 2024 Hi 28framelines, Take a look here Flash trigger for Leica MP . I'm sure you'll find what you were looking for!
sometimesmaybe Posted January 24, 2024 Share #2 Posted January 24, 2024 18 hours ago, 28framelines said: I have a Godox AD100Pro, and I am wondering what flash trigger I need to use to get it working properly godox does make a leica trigger but that's for the m10/SL - the pin layout is different. i'd recommend try taping up the contacts on the trigger first (just expose the centre pin). see if that solves the issue. a normal pc sync cable should work just fine, they are really cheap at places like ebay. if you want to use it remotely with your x2t i think from memory you need a pc sync to 2.5mm jack. if you plan tether it straight from your MP to the ad100 you might need a pc sync to 3.5mm jack. also just make sure you have your SS at the MP's max sync speed or below 1 Link to post Share on other sites More sharing options...
28framelines Posted January 25, 2024 Author Share #3 Posted January 25, 2024 Thank you! I will try to get a PC Sync cable first. The X-Pro II seems like overkill given I don’t have a digital Leica! Link to post Share on other sites More sharing options...
