I think so ...
• Rapid flashing of the two LEDs (> 2 Hz) when charging commences
indicates a charging error (e.g. maximum charging time exceeded,
voltages or temperatures outside permitted ranges or a
short circuit). Disconnect the charger from the mains and remove
the battery. Ensure that the above temperature conditions are
met and then restart the charging process. Please contact your
dealer, the Leica representative in your region or Leica Camera
AG if the problem persists.
The orange LED on my charger is steady when the battery reaches 80%. Normally I only charge until this LED comes on, but the recent upgrade instructions said to fully charge the battery fully and I was surprised how long it took to get from 80% to 100%.
David
David
I was under the impression that 100% charge (and discharge to zero in-camera) was recommended for the first 2-3 charging cycles for a new batt, but that charging to 80% was recommended thereafter.
Interesting. Can you give an authoritative reference for this statement, please?
David
David
It doesn't get more authorative than this, I think. Manual says on page 11:
Edited by Ad Dieleman
  • Thanks 2
