Un saluto a tutti e vi chiedo un consiglio. Posseggo da 3 anni una Leica M10 con il Summicron 28mm f2 asph, il Summilux 50mm f1,4 asph, lo Zeiss Sonnar 50mm f1,5 e l'Emarit 90mm f2,8. La mia focale preferita con cui scatto l'80% delle mie foto è il 50mm, ora vorrei completare il mio corredo con una focale intermedia tra 28 e 50 che mi permetterebbe di uscire con un unica focale. La caratteristica principale è che sia minuscolo e la mia scelta è ricaduta sul Summicron C 40mm f2 o sul Voigtlander Nokton Classic 35mm f1,4 o nella versione MC o SC (forse preferirei quest'ultima), entrambi hanno lo stesso prezzo (Summricon usato e Voigtlander nuovo). Chiedo un consiglio a chi possiede o ha posseduto queste lenti. Grazie
Edited by Riccardo.asselta
Ciao @Riccardo.asselta
Loro sono due bestie diverse!
Regarding your current lens inventory, you will be much happier with Summicron 40. I have owned both and now own only the Summicron. It is my main travel lens. It has the charm and character but not too much - the Nokton has much more of it (glow and all) wide open.
Consider this: Summicron 40 is the beefed-up clone of Summicron 35 II/III (see this article by Marco Cavina in Italian) and Nokton Classic 35 is the clone of Summilux 35 Pre-asph Steel Rim (click the links).
There are threads with image samples for both lenses on this forum - here for Summicron 40 and here for Nokton 35..
Edited by Al Brown
I have both the Summicron 40 and Nokton 35 1.4 II MC. I think overall the Summicron is a bit sharper, but in most cases differences are minor. I now use the Summicron only on mt film CL - the camera it was designed for and has 40mm VF frame. The Nokton is my main lens on my M9, (On M10 I mainly use a Summarit 35 2.5 for its small size, great handling, and excellent images. I prefer it to the other 35mm lenses I have, including Summicron.) The Nokton has more distortion and isn't quite as sharp, but I don't notice this in most work.
2 minutes ago, Riccardo.asselta said:
Grazie Al Brown link molto interessanti.
TomB_tx il Summarit ha un costo decisamente superiore.
Cost of the Summarit is higher - I bought mine used when prices were lower. The Nokton is a very good buy for its features and performance.
