Transfer speed between iPhone and Leica Q3 - USBC wired connection is much slower than wireless connection
Hi,
I have setup my connection to my iPhone (15 Pro) for both wired and wireless connections with my Leica Q3 camera. I am seeing that the transfer speed while using wireless connection is many times faster than the transfer speed while using the USBC cable connection. The USBC cable is the official Apple provided (USBC-to-USBC) so I know that not the issue.
Anyone else is seeing something similar?
Thank you!
vor 2 Stunden schrieb SG1:
This is exactly your issue. This is a charging cable not intended for data transfer. If you want faster speeds, get a usb-c data cable that is capable of 10Gbps as that is what I believe the iPhone 15P is capable of.
I thought that the USBC cable provided by Apple is a data cable. Anyway, I have a Thunderbolt3 data cable that I use to connect my external SSD drive and the speed is low - the same. Can you tell me what cable are you using for this? Maybe even this one is not right.
Thanks!
Edited by SG1
This is the correct answer. The included cable is USB 2 speed (480Mbps, 60MB/s max). From what I'm seeing, the Q3 supports 35MB/s max over Wi-Fi, so it's strange that Wi-Fi is outperforming even the USB 2 cable...
Generally speaking, if you want to maximize speeds you'll need something that supports USB3 like this.
Edited by anonymoose
Hi again, I also sent this question to Leica customer support and I received the following response:
Thank you very much for your e-mail.
 It is correct, the transfer speed via USB-C cable is currently much slower than the wireless transfer speed.This will be fixed via firmware 2.0 for which I do not yet have a release date.
If you have any further questions, please do not hesitate to contact us.
Looks like this is a real problem they are planning fix sometimes hopefully soon...
In regards to the last comment - yes, if we put the camera in USB storage mode, we are seeing is in Files and can download them this way. But we cannot see the photos from the Leica FOTOS camera.
Thank you for the community help!
vor einer Stunde schrieb SG1:
What’s the point in importing them to the Fotos app? Afaik you can’t do anything with dngs there and the app will prompt you to send them to LR or Darktable anyway? So import them directly to the App you‘re going to edit them with or if you just want to keep a copy on your phone import them to the Files App.
You are bringing a good point! Never used the "Files" app for anything. And once the files are in the cloud we can see them everywhere (even on the Mac) - I need to experiment this usage model.
I transferred one file and it's really fast. So the issue might be connected to Fotos...
Thanks!
