Hi, just got a M10M and it has some small scratches (see picture), any experience in how to remove these?
Is it a coating here that i will destroy if I'm using toothpaste and water ?
  • 2 weeks later...
@Derbyshire Man No, i haven't. I can't see it at all when taking pictures and you need to get it in the right light to see it too.. Its extremely minor
Living in Norway, and to the best of my knowledge, it means i would need to send the camera to Germany for fix. Which takes for ever.
So no, didn't check price on this.  I like to be able to fix things myself :)
I now i can get this scratch out, but i need to now if there is a coating there that would end up be destroyed.
Edited by Tor-B
@250swb Unfortunately yes, i'm 100% sure its a small scratch and not grime :(
You can destroy coating with toothpaste and or rubbing compound , but it will also deal with the scratch there (most likely )
I also just contemplating on leaving it as is. You can't see when you are actually using it.
