x
Take the camera in a dimmly lit room with some bright light sources (lamp or TV) and put the light source to the right. Then watch the left side of the EVF. Or even more simple: Turn on teh historgram which appears in the upper left hand corner. An upside down reflection can be seen in the lower right corner.
7 hours ago, clasami said:
Problem solved! The camera is pre-owned, and the previous owner has put an inexpensive "protection" on the EVF. After removal, no reflections anymore.
Small update: The bad reflections are gone. But upon closer inspection, there are very discrete reflection even without the protective cover. Nothing to worry about - but they are there.
  • 2 months later...
vor 2 Stunden schrieb Ou812b4:
Hi Clasami, I seem to have the same issue with my new Q3. Was wondering if you had looked into this further or just accepted as a limitation of the camera?
My previous post: "Problem solved! The camera is pre-owned, and the previous owner has put an inexpensive "protection" on the EVF. After removal, no reflections anymore." But a new Q3 shouldn't have that kind of protection on the EVF.
