tgj Posted December 10, 2023 Share #1 Posted December 10, 2023 Advertisement (gone after registration) Hello everyone, This is my first time posting here, so please bear with me. I've been a long-time shooter with the Fujifilm X-Pro2, but I'm now looking to venture into something different, specifically beyond the APS-C format. I'm considering the GFX50R and the Leica SL, which are similarly priced on the used market. I really appreciate both of these cameras, especially for their color rendering. As a hobbyist, my main subjects are travel, cars, and once a while I will get paid gigs for portraits for graduation photos. Which of these two cameras would you recommend for someone with my interests? Link to post Share on other sites More sharing options...
Advertisement Posted December 10, 2023 Posted December 10, 2023 Hi tgj, Take a look here GFX50R vs Leica SL typ 601. I'm sure you'll find what you were looking for!
lik Posted December 11, 2023 Share #2 Posted December 11, 2023 Welcome! I understand this choice dilemma very well because I had it too. And yes – in color rendering they're both excellent. Pro GFX50R: great MF-Sensor, less expensive Fuji lenses, endless options for film simulations Pro SL601, better / fast AF, usability of a good unser interface I had the SL601 and now I have the Fuji GFX100II. The reason is that I definitely wanted a MF with 100 MP for large format prints. I wouldn't have changed if I hadn't this motivation. For travel, street and portraiture even this most recent very modern and tempting GFX100II has an AF not as fast as the SL601. An MF -System as the only one IMO should be considered very carefully. To me it would never be an option if I had no FF-System in addition. So it clearly depends on your priority when using a camera. Another aspect is the results, in particular what is considered the "MF-Look". If you really – really (!) – like it, there is no alternative. Any choice is a progress compared to APS-C. So anything you do is wrong, but do it. 😉 Link to post Share on other sites More sharing options...
tgj Posted December 12, 2023 Author Share #3 Posted December 12, 2023 Thank you both for your replies! It seems like you both really prefer the look of the GFX50R, and indeed, the medium format look is amazing. I should probably test out both, but I'm not sure how to go about that. I was quite set on the GFX50S2 and was planning to save up for it, aiming for a purchase by fall 2024. However, I realized that the Leica SL1 is about $1,800 and the GFX50R is around $2,500. I can comfortably afford the SL1 right now. I thought the Leica might retain its value better before I move to something more expensive. But, I can also afford the GFX50R. If I opt for the SL1, I can use my M lenses, which I've adapted for Fuji, and probably buy an R lens. However, if I choose the GFX, I might have to wait or just buy the pancake lens. Link to post Share on other sites More sharing options...
vinoeolio Posted December 12, 2023 Share #4 Posted December 12, 2023 Not easy to decide...... I have no experience with the Fuji GFX, but with the larger sensor, one can expect very hight quality. I personally swapped end of 2019 from a M10 to the Leica SL 601 and changed it to a SL2-S early 2022......but the SL2-S was a disappointment for me - shutter shock (due to IBIS) blurred images at 1/60 - 1/250, I also preferred the 4 switch layout of the 601 and I find the 601 more robust than the SL2..... End of the story, after my SL2 showed an error (top display stayed on, with power switch off) I decided to part with the SL2 and bought a second hand SL 601 and I am a happy man again - SL 601 works perfectly with my M lenses and ISO performance is only one EV less than the SL2-S...... If 24MP is enough for you, go for the SL 601 - even in 2024 still a great camera Josef Link to post Share on other sites More sharing options...
