I've been using the M11M with Visoflex2 happily, with grid and level for some time.  More recently they have just vanished from the screen, and no amount of menu hunting can reinstate them.  I'm sure I've not inadvertantly removed them.  I have just updated to 2.0.2 firmware with no effect.  Has anyone come across this?
x
4 minutes ago, des hill said:
thanks for reply, yes, quite deep, too deep to 'accidentally' cancel anything.  So I've tried to set up a profile with grids 'switched on' to no avail, unfortunately.  Will have another try later though.
Also, keep in mind that you need to push the center button to cycle through the info pages. I think by default, one is a blank screen, devoid of any capture assistants. You may be viewing that one?
Yes, and as far as i can see, i have.  Profile#1 shows on the menu home screen as being in use.
