Nicled Posted November 25, 2023 Share #1 Posted November 25, 2023 (edited) Advertisement (gone after registration) Q2 - when video us accidentally activated, its hard to return to photo mode. Even when you swipe it continues on video. I need to turn the cam off and go to my profile again. Swiping doesn’t help. Any suggestions? Edited November 25, 2023 by Nicled Link to post Share on other sites More sharing options...
Advertisement Posted November 25, 2023 Posted November 25, 2023 Hi Nicled, Take a look here Q2 - when video is accidentally activated, its hard to return to photo mode. . I'm sure you'll find what you were looking for!
Siriusone59 Posted November 25, 2023 Share #2 Posted November 25, 2023 The "select" button in the center of the arrow pad should let you toggle between modes, just watch the icons on the screen or in viewfinder to make sure you stop on the desired mode. That's how I change it on my "Q" and I assume the "Q2" works the same. Link to post Share on other sites More sharing options...
Nicled Posted November 25, 2023 Author Share #3 Posted November 25, 2023 It hangs even if i press the center button especially when it accidentally activates when the LCD touches my shirt and swipes to video mode. If it is activated naturally there is no problem. Link to post Share on other sites More sharing options...
LocalHero1953 Posted November 25, 2023 Share #4 Posted November 25, 2023 (edited) Swiping only comes into play if you use the LCD for live view, which I do not. I have EVF/LCD display set to EVF Extended. For the rare occasions when I want to use video, I use the Quick Start (graphical) menu, and just touch Video or Photo (or use the arrow buttons to navigate). I have just tried the swiping option and it seems to work as per the manual. Of course a single test like this won't find occasional/intermittent errors. The Q2 manual, which I have just downloaded, seems to be incorrect about the centre button: it just cycles through display info options (black bars, histogram, nothing). Maybe the writer (or translator) got confused with the right wheel button. Under Customise Control, you can select the options for the Right Wheel Button; turn the Photo-Video option to On, and all others Off. The Right Wheel Button will now toggle between Photo and Video. (You don't actually have to turn all the other button options Off. If you have any others set to On, then you will have to start by a long press on the Right Wheel Button, and select Photo-Video as your normal short press action.) Edited November 25, 2023 by LocalHero1953 Link to post Share on other sites More sharing options...
Nicled Posted November 27, 2023 Author Share #5 Posted November 27, 2023 Thanks everyone! Link to post Share on other sites More sharing options...
