Leica SF C1 flash controller: does it work with other camera brands?
I have 2 SF 60 flashes also and the system worked well when I used the SL system which I no longer have.  I just ordered the Hasselblad X2d and would like to know if the controller can be activated by this camera or is it Leica specific.
8 hours ago, Photoworks said:
TTL systems are not interchangeable
'it will only work with Leica
You can use the SF C1 with your other cameras if you set a manual power option. Just like many other systems.
Thank you Photoworks.  I don't need TTL as I would be using a flash meter.  Too bad the controller doesn't have a PC sync port as I would like to use it when shooting film on my TLRs as well.
7 hours ago, Photoworks said:
you can get a hotshoe adapter to PC sync cable
Thank you again. I just remembered I have 3 either NOS or practically new Nikon SB16 flashes in storage that I can also retrieve along with Pocketwizards to see if the Rolleiflex TLRs trigger the flashes.  I also have an older Seikonic 358 flash meter with the PW module to enable remote triggering.
I just used the SF C1 and 2 SF 60s with my M11P for the first time and it worked perfectly in TTL mode.
Edited by ymc226
