90mm APO and B+W slimline filter
stunsworth
Hi Mark, thanks for the quick response.
The problem with the slimline B+W isn't the fact that it's not a Leica filter, it's that the outer part of the metal ring has a larger diameter than the standard filters - this prevents the lens hood on a 24mm Elmarit from being mounted for example - I was wondering if the extra diameter would foul the lens hood on the 90mm lens.
Steve,
I have the APO 90 and a B&W 55mm 486 filter (but I'm not sure whether it's the slimline - how d'you tell?) and there's no problem at all. The thickness of the filter's rim plus thread is about 7mm and the thickness of the rim is about 4mm.
With the filter in place and the hood extended there's a good 2-3mm clearance between filter and hood all round. BTW, the pinch-on cap also attaches with the filter in place.
Pete.
(Apologies for the cross-posting.)
Pete, the easiest way to hell is to look to see if the front of the filter is threaded. If there are threads then it's not the slimline version.
Steve,
"To hell"? :D I didn't think it'd be a mortal sin - or whatever - so I looked anyway and there is a thread so its the fat-line(?) filter, which would be 'worse case' than the slimline.
Thanks for the info.
Pete.
