Hi all,
I’ve owned my m10r for a couple of months or so now and have found that the metering is a little different to my previous Leica M cameras. When I’m not in manual, which is quite often in flat light, I find I have to set exp comp to +1 to get close to an accurate exposure. Just wondering if anyone else has experienced the same thing?
Thanks
Costa
Yes, I've noticed it also.  I've gotten into the habit of fooling my meter by tilting the camera down so it can meter off the grass and half pressing the shutter to lock the exposure before raising to frame and finishing pressing the shutter release.  It works for me but should I forget or not have the opportunity to do that, I'll just bring up the shadows in Lightroom.  The exposure latitude is wide enough to permit it to be fixed.  I'm thinking that Leica changed how the camera meters to help prevent blown out highlights.
My thought was also that it was for the highlights but I’ve found that the m10r excels in this area when accurately exposed. Better than any other camera I’ve owned in fact.
26 minutes ago, GFONG said:
When using rangefinder, the camera is using center weighted metering regardless which metering method is chosen. All three metering methods work with Live View.
Yes, I’m aware of this but I’ve found the m10r tends to underexpose by 2/3rds to 1 stop depending on the scene even if it is not high contrast, difficult lighting etc.
When using the M10P, I needed to -2/3 EV. For my M10R, so far I found that it is quite accurate even though it is using center weighted metering.
That’s interesting, maybe it’s the funky light I’m getting where I live but I find they come in under most of the time even in flat dreary conditions.
I agree and have the same experiences, although it’s mostly in the typical landscape setting of bright sky and normal earth, and also in interiors with highlights. It seems that the M10-R   lightmeter overrates the highlights. To be sure I always measure the light on my hand, followed by Siriusone59’s method.
Isn’t this adjustable with a firmware update? Because when I analyze my shots on my Mac the underexposure isn’t as bad as seen on the LCD-screen during the shooting. I do not remember whether the M10 had an Auto Display Brightness of the screen, but the M10-R has. If I set the brightness not Auto but at Medium high or High, I evaluate the shots less underexposed during a shooting session.
Edited by otto.f
I can’t see too much of a difference between the back screen on camera and my computer but I’ve not really compared. I will check it later today also for my curiosity.  I should think firmware could improve the back screen accuracy but I doubt Leica would ever entertain us with an update!
I also meter off the floor a fair bit but tend to revert to manual where I’ve memorised over the years different settings for f8 depending on the light and then go from there.
On 10/29/2023 at 3:43 AM, costa43 said:
Hi all,
Thanks
Costa
Which metering mode are you using? Center Weighted? I've had better luck with Multi Field.
Multifield does not work with optical rangefinder as far as I know
