scvpic Posted September 25, 2023 Share #1 Posted September 25, 2023 Advertisement (gone after registration) Leica M-A curtain jammed on film. Did I load the film incorrectly? How could that happen… Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/382393-how-to-fix-curtain-jam-on-film/?do=findComment&comment=4864681'>More sharing options...
Advertisement Posted September 25, 2023 Posted September 25, 2023 Hi scvpic, Take a look here How to fix curtain jam on film. I'm sure you'll find what you were looking for!
maxfairclough Posted September 26, 2023 Share #2 Posted September 26, 2023 Mate, literally going through this now. All I am saying is good luck. Parts not in until at least January. Link to post Share on other sites More sharing options...
scvpic Posted September 26, 2023 Author Share #3 Posted September 26, 2023 Okay. I was able to move the curtain slightly backwards, releasing the film. Then I opened the back door and was able to see the film was not loaded correctly and not being taken up. Camera functioning fine now. 2 Link to post Share on other sites More sharing options...
madNbad Posted September 26, 2023 Share #4 Posted September 26, 2023 First, welcome to the forum. Secondly, follow Leica's loading instructions. Remove the baseplate, start by inserting the cassette just enough you can pull the leader across to drop through the tulip prongs, seat the cassette in the well, insuring it's in contact with the rewind crank. Replace the baseplate and wind. Check the rewind to make sure it's moving. No need to open the door and try to align the film. No need to start advancing the film before replacing the baseplate. There is a ton of information on LUF about loading the camera. It's unfortunate it happened but a good reminder to all of us. 1 1 Link to post Share on other sites More sharing options...
250swb Posted September 26, 2023 Share #5 Posted September 26, 2023 (edited) In addition to @madNbad's advice you should make sure the sprocket teeth (the gear teeth you can see just to the left of the film loading prongs) are engaged in with the sprocket holes along the edge of the film. The top and bottom teeth don't both need to be engaged with the film, but it doesn't hurt, because closing the door and fitting the baseplate will line everything else up. Edited September 26, 2023 by 250swb 1 1 Link to post Share on other sites More sharing options...
scvpic Posted September 26, 2023 Author Share #6 Posted September 26, 2023 Hey guys, thanks for the tips. I shot a lot on an M6 for a year, I just swapped it for the M-A. Never had the M6 jam which caused me to panic. But I did have a few occasions where I’d not shoot a roll cause I improperly loaded the film on the M6 (my fault). I just have to start trusting that ‘less is more’ with respect to loading and taking note that the indicator is moving when advancing. 1 Link to post Share on other sites More sharing options...
Huss Posted September 27, 2023 Share #7 Posted September 27, 2023 (edited) Advertisement (gone after registration) Leica's super simple instructions how to load film: https://www.fredmiranda.com/forum/topic/1825676/2#16350734 Edited September 27, 2023 by Huss Link to post Share on other sites More sharing options...
