Shane Oneill Posted September 18, 2023 Share #1 Posted September 18, 2023 Advertisement (gone after registration) over the weekend i have found that settings that i thought i had saved have changed, AF assist was set to off and then switches itself on, AFS reverts to IAF, function buttons chnage had set thumbwheel to perspective control and it's now back to ISO hwo do you save your settings so they become the default settings very annoyingly the day/date for some reason reset to january 2023 and wehn i try to adjust time/date on my batch of imported photos, it won't change any help gratefully received thanks Link to post Share on other sites More sharing options...
Advertisement Posted September 18, 2023 Posted September 18, 2023 Hi Shane Oneill, Take a look here savings camera settings on Q3 frustration. I'm sure you'll find what you were looking for!
Guest Posted September 18, 2023 Share #2 Posted September 18, 2023 You can't change the "Default Profile" settings. Whenever you select it the settings you have changed will revert to the default. You need to setup the Q3 as you like and then save to a new User Profile (Menu 4). You then select that, or any other user profile that you have saved, to restore your chosen configuration. Link to post Share on other sites More sharing options...
Shane Oneill Posted September 18, 2023 Author Share #3 Posted September 18, 2023 thanks Corius so it will always revert to default settings unless you selcet your user profile every time you turn the camera on? shane Link to post Share on other sites More sharing options...
LocalHero1953 Posted September 18, 2023 Share #4 Posted September 18, 2023 My Q2 restarts with the same settings as when it was switched off (usually the user profile I have named 'My Default'). It doesn't revert to Default. Link to post Share on other sites More sharing options...
Guest Posted September 18, 2023 Share #5 Posted September 18, 2023 21 minutes ago, LocalHero1953 said: My Q2 restarts with the same settings as when it was switched off (usually the user profile I have named 'My Default'). It doesn't revert to Default. Same with Q3. It will only revert to default settings if you select the "Default Profile", but you can't change the Default Profile, which is why you should create User Profiles for maximum flexibility and also to save you if you select the Default Profile by mistake. Link to post Share on other sites More sharing options...
idusidusi Posted September 18, 2023 Share #6 Posted September 18, 2023 1 hour ago, Corius said: Same with Q3. It will only revert to default settings if you select the "Default Profile", but you can't change the Default Profile, which is why you should create User Profiles for maximum flexibility and also to save you if you select the Default Profile by mistake. Yes already made that mistake two or three times on my borrowed Q. 'Default profile' should come with a warning!! Link to post Share on other sites More sharing options...
Bent Posted October 14, 2023 Share #7 Posted October 14, 2023 Advertisement (gone after registration) But can you save settings to the sd card, for back-up purpose, or if you have a really good friend who would like to use your settings? Link to post Share on other sites More sharing options...
Le Chef Posted October 14, 2023 Share #8 Posted October 14, 2023 5 hours ago, Bent said: But can you save settings to the sd card, for back-up purpose, or if you have a really good friend who would like to use your settings? Yes. Link to post Share on other sites More sharing options...
