x
1 hour ago, werner__ said:
Kontrast ist deutlich zu sehen, ansonsten sagt das Bild zumindest mir, so gut wie nichts
Apart from me thinking, that it is impolite to not write in English in this part of the forum - what exactly could have been done better to get a more interesting picture in your opinion? I see a very well executed portrait with a thoughtful use of light that does justice to the beauty of the pictured woman. I wish I had more opportunities to produce pictures on the level that Marc constantly achieves. But I may be biased towards this kind of photography 🤷‍♂️
vor 21 Stunden schrieb stuny:
The contrst between her lightness and the black background conspire with her direct look to be intense by soft.
Thank you very much Stuart, I had exactly the same impression when I saw this photo for the first time.
vor 21 Stunden schrieb werner__:
Hilft nix Werner, da musst Du einfach durch
vor 20 Stunden schrieb Sparkassenkunde:
Thank you very much James, this is very kind of you. Hope to show more portraits which you like.
