robb Posted September 17, 2023 Share #21 Posted September 17, 2023 Advertisement (gone after registration) On 9/15/2023 at 10:31 AM, tangosix said: I use the b10x and the A2 with the connect remote which is so discreet, small and incredibly useful. I also use the new Pro Connect with full auto. So far I have tried to avoid an on-camera flash. I either mount the strobes ahead of time at the event or recruit an assistant with the A2 handheld Yes, I probably need the a10 on camera set up for more discreet versatility at events and receptions, but I simply prefer the results from the a2 with small clic softbox more. They carry well everywhere also. I really enjoy using the connect on the M11 as well. That is a nifty trick. This image in a dark nightclub would not have been possible without the A2. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! I’m in the same boat with Tangosix. profoto b10 and a2 off camera with a remote in the hot shoe. couldn’t imagine better solutions but I don’t use flash for run and gun. Robb 1 Link to post Share on other sites More sharing options...
Advertisement Posted September 17, 2023 Posted September 17, 2023 Hi robb, Take a look here Any advise for a good flash for SL2-S ? . I'm sure you'll find what you were looking for!
Simone_DF Posted September 22, 2023 Share #22 Posted September 22, 2023 On 9/14/2023 at 9:52 PM, Camaro5 said: Yes, very much so. At 1/8 to 1/4 power (with the diffuser) it's enough for the automotive stuff I do without being too bright. The diffuser seems to even out the brightness. It also has a low profile and looks good on the camera. The diffuser was cheap but hard to find. Had to get mine from China but it was only about $6. Thank you. Just got the Godox Lux and the diffuser. Link to post Share on other sites More sharing options...
Photoworks Posted September 24, 2023 Share #23 Posted September 24, 2023 I just getting the 3rd SF 60 packed up for repair, it stopped powering up. The SF 40-60 is the only flash I have found to work across all Leica systems. The SF-60 soffer from old design. Newer flash have all better batteries, quicker recharge time, can hold diffuser without flapping down all the time, and don't overheat. SF-60 is based on Nissin design of the i60a ( already discontinued) If you are using the SL2 you have other options if you need TTL and HSS. Profoto and Godox came to mind. Currently, I am using a godox V860II + Godox Leica trigger, a bracket and Gary Fong Diffuser ( after testing many of them it is the softest one out there, the V1 round head is cure, but not great for bounce) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/382001-any-advise-for-a-good-flash-for-sl2-s/?do=findComment&comment=4863817'>More sharing options...
PK Bhattacharyya Posted January 21, 2024 Share #24 Posted January 21, 2024 Friends, can I use Godox V860IIN safely on my SL2-s? I also have a Digitek DFL-088 for my other cameras. I have a DRM-009 trigger to work with it. Thanks in advance for your advice. Link to post Share on other sites More sharing options...
bpLeica Posted January 23, 2024 Share #25 Posted January 23, 2024 It depends on the use case but I don't see any benefit for on camera flash. Going through a bunch of options, I landed with the Elinchrom One as the best solution for flash when I need it. Bulky but does the job. Link to post Share on other sites More sharing options...
PeterBoyadjian Posted January 23, 2024 Share #26 Posted January 23, 2024 profoto a10, my most important tool 1 Link to post Share on other sites More sharing options...
