clasami Posted September 9, 2023 Share #1 ย Posted September 9, 2023 Advertisement (gone after registration) Been using this mode for the first time at a recent event. The reception was like 60 people outisde in the garden. The image in the viewfinder almost looked like a an ego-shooter video game ๐ So many frames dancing around bodies and faces - almost impossible to manage. Okay with two or three people in the frame. But not all usable for groups, I think. Link to post Share on other sites More sharing options...
Advertisement Posted September 9, 2023 Posted September 9, 2023 Hi clasami, Take a look here Q3 - Eye, Face, Body Detection . I'm sure you'll find what you were looking for!
Voxen Posted September 9, 2023 Share #2 ย Posted September 9, 2023 I hope they will update this with more discrete boxes, like semi transparent or something less visible. Link to post Share on other sites More sharing options...
clasami Posted September 9, 2023 Author Share #3 ย Posted September 9, 2023 vor 16 Minuten schrieb Voxen: I hope they will update this with more discrete boxes, like semi transparent or something less visible. Or even better: Have Face/Eye detect mode seperate from body detect. Limit distance at which a face is detected so that only people close to the camera are detected.ย 1 Link to post Share on other sites More sharing options...
mholeica Posted September 9, 2023 Share #4 ย Posted September 9, 2023 3 hours ago, clasami said: Been using this mode for the first time at a recent event. The reception was like 60 people outisde in the garden. The image in the viewfinder almost looked like a an ego-shooter video game ๐ So many frames dancing around bodies and faces - almost impossible to manage. Okay with two or three people in the frame. But not all usable for groups, I think. Absolutely unusable or you shoot and hope. What did you do in the end? Field? Link to post Share on other sites More sharing options...
Miltz Posted September 9, 2023 Share #5 ย Posted September 9, 2023 The face and body detection on the Q3 is pretty awful. My Z6 from 2019 destroys it. Itโs probably the only thing I donโt like so far.ย Link to post Share on other sites More sharing options...
clasami Posted September 9, 2023 Author Share #6 ย Posted September 9, 2023 vor 1 Stunde schrieb mholeica: Absolutely unusable or you shoot and hope. What did you do in the end? Field? Switched back to AF-S, Spot. Link to post Share on other sites More sharing options...
mholeica Posted September 9, 2023 Share #7 ย Posted September 9, 2023 Advertisement (gone after registration) 1 hour ago, clasami said: Switched back to AF-S, Spot. Do you tap the screen to move the spot or use the buttons to move it? Itโs so small I find that it so hard to use it to keep up with subjects.ย Link to post Share on other sites More sharing options...
clasami Posted September 9, 2023 Author Share #8 ย Posted September 9, 2023 vor einer Stunde schrieb mholeica: Do you tap the screen to move the spot or use the buttons to move it? Itโs so small I find that it so hard to use it to keep up with subjects.ย No, don't use touch screen - and it is just too busy to control. Link to post Share on other sites More sharing options...
geesbert Posted September 13, 2023 Share #9 ย Posted September 13, 2023 I think the best solution would be something like Canonโs option to reduce the possible AF modes to two or three and then switch between them by an f button. I have that with my r5, where I have one button to press to switch between face detection and spot AF, so that I could pick one face out of a group should I need to 1 Link to post Share on other sites More sharing options...
LocalHero1953 Posted September 13, 2023 Share #10 ย Posted September 13, 2023 It is one failing of Leica's interface: whether it's the M, CL, SL or Q, they do not allow direct actions to be assigned to a button, only menu options. So you can't toggle between two or more states with a button press (e.g. MF-AFs-iAF, Field-Face). Maybe its a deliberate choice, or maybe it's a fundamental limitation of their firmware systems, but it's wrong, IMO. 3 1 Link to post Share on other sites More sharing options...
hoolyproductions Posted September 13, 2023 Share #11 ย Posted September 13, 2023 4 hours ago, LocalHero1953 said: It is one failing of Leica's interface: whether it's the M, CL, SL or Q, they do not allow direct actions to be assigned to a button, only menu options.ย Totally agree, although there are some minor exceptions on the SL2: changing the view mode (histogram, focus peaking, etc, which I use a lot); Depth of Field Preview, magnification on/off, and APS-C mode (technically two button presses but you don't need to scroll or remove your eye from the EVF). I do often need to switch between field and face focus, would be nice to see this also! 3 Link to post Share on other sites More sharing options...
