clasami Posted August 25, 2023 Author Share #21 Posted August 25, 2023 Advertisement (gone after registration) vor 12 Minuten schrieb thighslapper: Are you sure it's not down to the EVF being less contrasty than the Q2 one ? Perceived sharpness is a combination of resolution and contrast. Without both cameras to compare side by side it's hard to comment on what's going on here. Side by side, contrast seems to be the same. There is more shimmering with the Q3 which leads to a perceived lack of sharpness. Wonder if that has to do with resolution at 3x. On a different note, I find 6x on both models not very exciting. Link to post Share on other sites More sharing options...
Advertisement Posted August 25, 2023 Posted August 25, 2023 Hi clasami, Take a look here Leica Q3 EVF sharpness in MF . I'm sure you'll find what you were looking for!
thighslapper Posted August 25, 2023 Share #22 Posted August 25, 2023 (edited) On 8/23/2023 at 2:25 PM, clasami said: P.S. EVF is at 60Hz. 120Hz is even worse Given the wonderful EVF and the totally sharp image it shows in playback mode, it should be able to do better. There is more shimmering with the Q3 which leads to a perceived lack of sharpness That does seem to imply it's something to do with the way the firmware is rendering the cropped area of the sensor and can't really be a hardware issue. If I recall correctly 'shimmering' was a feature of the original clip-on EVF for the M240 ..... and the way it came and went actually (accidentally) gave you confirmation you were in focus ...... a sort of unintentional peaking (the actual peaking was pretty useless). Edited August 25, 2023 by thighslapper Link to post Share on other sites More sharing options...
clasami Posted August 25, 2023 Author Share #23 Posted August 25, 2023 vor 13 Minuten schrieb thighslapper: That does seem to imply it's something to do with the way the firmware is rendering the cropped area of the sensor and can't really be a hardware issue. If I recall correctly 'shimmering' was a feature of the original clip-on EVF for the M240 ..... and the way it came and went actually (accidentally) gave you confirmation you were in focus ...... a sort of unintentional peaking (the actual peaking was pretty useless). Yes, that was how some folks interpreted the "shimmering" on the a7r2 🙂 Don't think it is a hardware issue, either. It is more like running your PC screen not at the optimal resolution - which makes text look less sharp. 1 1 Link to post Share on other sites More sharing options...
jplotkin Posted August 28, 2023 Share #24 Posted August 28, 2023 Have you tried turning off iDR (intelligent dynamic range), or, better yet, set to save DNG (no JPG)? Does the EVF MF sharpness problem persist even with DNG only? Link to post Share on other sites More sharing options...
clasami Posted August 28, 2023 Author Share #25 Posted August 28, 2023 vor 51 Minuten schrieb jplotkin: Have you tried turning off iDR (intelligent dynamic range), or, better yet, set to save DNG (no JPG)? Does the EVF MF sharpness problem persist even with DNG only? Yes, iDR is off and it is DNG only. JPG & DNG makes no difference, regardless of JPG size. Neither does JPG only, regardless of size. Link to post Share on other sites More sharing options...
huwm Posted December 15, 2023 Share #26 Posted December 15, 2023 Was there a resolution to this issue? I've just got a Q3 and shimmer in the EVF is maddening 1 Link to post Share on other sites More sharing options...
clasami Posted December 15, 2023 Author Share #27 Posted December 15, 2023 Advertisement (gone after registration) 1 hour ago, huwm said: Was there a resolution to this issue? I've just got a Q3 and shimmer in the EVF is maddening Sold the Q3 and kept the Q2. It was good in some ways (mostly I liked the new control layout). That solved the issue 🙂 1 Link to post Share on other sites More sharing options...
Knorp Posted December 15, 2023 Share #28 Posted December 15, 2023 1 hour ago, huwm said: Was there a resolution to this issue? I've just got a Q3 and shimmer in the EVF is maddening I'm sorry for the shimmer. That's really too bad. Have you changed any settings ? If so load the default profile and see if that helps. Link to post Share on other sites More sharing options...
huwm Posted December 15, 2023 Share #29 Posted December 15, 2023 I've dropped the refresh to 60hz which has helped a bit and gone for a straightforward field focus with AFs Link to post Share on other sites More sharing options...
