maxpower Posted August 9, 2023 Share #21 Posted August 9, 2023 Advertisement (gone after registration) This thread (and previous ones) made me curious so I finally got a 720nm filter for my M10M and did some test shots outside today, all handheld. Let's just say the majority of the photos were not good and I underestimated how different it is a lot (I also don't have an EVF). But it's been interesting to play with so I do think I'll keep it for fun. Thought I'd also share some of my test shots to give impressions from someone much less experienced as well; all taken with the 35mm Summilux-M "Steel Rim" reissue. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 3 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/380586-infrared-on-monochrom/?do=findComment&comment=4831776'>More sharing options...
Advertisement Posted August 9, 2023 Posted August 9, 2023 Hi maxpower, Take a look here Infrared on Monochrom. I'm sure you'll find what you were looking for!
ramarren Posted August 9, 2023 Share #22 Posted August 9, 2023 It's been a very long time since I did much IR photography. However, once upon a time when I did, I remember that the rough estimate of the focus correction needed was approximately 1/70 * the focal length of the lens (in other words, for any given focus distance X, extend the focusing mount by approximately 1/70th of the focal length for IR at that same focus distance.) For a 50mm lens, this correction extension would be about .714mm, for a 200mm lens, it would be about 2.86mm. This makes sense because light filtered down to the near-IR range is a longer wavelength than the average of full spectrum white light, so the lens needs a little more extension to allow that wavelength to come to its optimum focus point. As a point of practicality, I then looked at my Hasselblad V system lenses which are all unit-shift focusing designs. These lenses do have IR correction marks. In all four of my V system lenses (50, 80, 120, and 150 mm), the IR focus correction mark is coincident with the far limit on the DoF scale marking for f/8. As a test of what that setting is doing, I measured the difference in lens extension that it produced with a dial gauge between setting the infinity mark at the standard index and then at the f/8-IR correction mark. In all cases, the difference in lens extension was vanishingly close to 1/70 * focal_length ... Happily, Leica M lenses tend to have DoF scale markings on them, and most are unit-shift lenses too. So, with a dial gauge and a nice small camera stand, I could measure the distances in lens extension between the nominal mark and the f/8 far mark on a set of them and test that against the "1/70 of focal length" rule of thumb, and make exposures to test that that works as a simple rule of thumb. I've got both 720nm and 650nm IR pass filters floating around here somewhere. It's a simple thing to just try setting one exposure at the nominal normal focus point and then making a second exposure with the nominal distance mark shifted to the f/8 far DoF mark, and see what you get. I haven't done this test for lack of time and desperate interest, and because I can't put my fingers on my IR pass filters just at the moment, but I suspect any suitably motivated person could... G 1 Link to post Share on other sites More sharing options...
Alan Friedman Posted August 10, 2023 Share #23 Posted August 10, 2023 (edited) An interesting report on the mechanics of focusing at different wavelengths of light. At one time I was doing a lot of photography of the planets using a 10" telescope working at a focal length of 7000mm. The camera was an industrial monochrome streaming camera and I would use a filter wheel with red, green, blue and IR pass filters mounted. When the atmospheric turbulence was low (good seeing) I would definitely notice a change and need to refocus between each of the filters. Fortunately the live view on the M11M (and also on the M10M, I would guess) works very well for direct focus through an IR filter... at least at 720nm. I had thought there might be some hassle - refresh rate or some other functional impairment at the long exposures I was using. But I found this not to be the case and live view focus was both effortless and accurate. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited August 10, 2023 by Alan Friedman 7 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/380586-infrared-on-monochrom/?do=findComment&comment=4832824'>More sharing options...
Alan Friedman Posted August 10, 2023 Share #24 Posted August 10, 2023 (edited) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Lake Days... Leica M11M + CV Apo-Lanthar 50 + Kolari Vision 720nm IR pass Edited August 10, 2023 by Alan Friedman 4 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Lake Days... Leica M11M + CV Apo-Lanthar 50 + Kolari Vision 720nm IR pass ' data-webShareUrl='https://www.l-camera-forum.com/topic/380586-infrared-on-monochrom/?do=findComment&comment=4832867'>More sharing options...
Alan Friedman Posted August 11, 2023 Share #25 Posted August 11, 2023 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! same set-up as above. 5 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! same set-up as above. ' data-webShareUrl='https://www.l-camera-forum.com/topic/380586-infrared-on-monochrom/?do=findComment&comment=4833301'>More sharing options...
Pintpot Posted September 7, 2023 Share #26 Posted September 7, 2023 Manchester University campus, M246 +35mm Colour scopar, 720 Heliopan filter. Handheld at 1/15th f16 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/380586-infrared-on-monochrom/?do=findComment&comment=4852086'>More sharing options...
