Intermittently, the meter in my SL2 will just not turn on.  It does not matter what I do with the advance lever, it just plays dead. However, I know that the meter is getting power from the battery because the test button works flawlessly. The meter is accurate when it works.
There are days where the meter works all the time and there are days where it will work once and then stop for hours. If I leave the camera sit for a couple of hours, it will invariable work the next time I pick it up. I have found no rhyme or reason to how its behaving, but I would like to fix it.
Does anyone have any suggestions on what to try? Is this a problem anyone else has run into?
I have not found a service manual for the SL2. Is it difficult to get at the meter switch to see what might be going on? If its relatively simple, I might be willing to try it myself.
Edited by Marcel Samek
Not sure what to try? There is a basic circuit board in the camera and it may be as simple as a cold solder joint. If it were me, I would send the camera to Don Goldberg (DAG Camera Repair) He is a factory-trained expert on the Leicaflex cameras
