Matrouk Posted June 30, 2023 Share #1 Posted June 30, 2023 Advertisement (gone after registration) Hello there M11 enthusiasts, After using my 21mm viewfinder once on my new M11, I've noticed that the hot shoe does not hold the viewfinder (or its cover for that matter) securely anymore. When I try to slide the viewfinder, it sits very loosely and could quite easily fall off the camera. Seems to be an issue of a lack of resistance on the two small plates in the hot shoe. I've brought it up to Leica in Paris and apparently I'm not the only one. I've scoured the Forum though and couldn't find any mention of this issue. Has anyone else experienced this? There does not seem to be a solution to this defect - the proposed fix is to manually lift the plates with a flat head screwdriver once in a while. Now I don't mind a little DIY, especially on my old film cameras, but I'd like to think that hot shoe technology is something Leica should be able to master. I'm seriously disappointed with this quality control issue, which really goes against everything Leica stands and prides itself for. Adding to that the recent back plate scratching issues with the new M6, it begs to wonder whether the standards of engineering in Wetzlar are held at a level they once were. Thoughts? Cheers 1 Link to post Share on other sites More sharing options...
Advertisement Posted June 30, 2023 Posted June 30, 2023 Hi Matrouk, Take a look here M11 - Loose hot shoe won't hold viewfinder securely. I'm sure you'll find what you were looking for!
MyLeicaWorld Posted June 30, 2023 Share #2 Posted June 30, 2023 I have the same problem with my M11 and the 21 viewfinder.. it still holds tight for now but it will get loose in time as my M10 happened before.. solution? Well with my M10 I put an electric tape inside the hotshoe.. and it was tight after that.. but for a brand like leica; should I try to find a solution for such a thing? 2 Link to post Share on other sites More sharing options...
IMAGEPOWER Posted June 30, 2023 Share #3 Posted June 30, 2023 same issue here with both the silver and the black 21 viewfinder on the M11 Link to post Share on other sites More sharing options...
Kwesi Posted June 30, 2023 Share #4 Posted June 30, 2023 interesting! I have the silver 21 bright line finder and have been using it with no issues for about 5 years now. first on my M10-P and now on the M11 for about 18 months. I will start watching for it and adjust the resistance as needed. I would hate for it to fall of. Link to post Share on other sites More sharing options...
Pyrogallol Posted June 30, 2023 Share #5 Posted June 30, 2023 Thumb size scrap of paper between the finder and the camera will hold it. Millions of tiny pieces of paper available to use at no cost. Link to post Share on other sites More sharing options...
mujk Posted June 30, 2023 Share #6 Posted June 30, 2023 Seems to be a common problem. This thread discusses the same issue on the M10: Link to post Share on other sites More sharing options...
