Mink Posted June 21, 2023 Share #1 Posted June 21, 2023 Advertisement (gone after registration) I’ve been looking online for hours to find if TTL will work between a 24D flash and a Q3. I can’t seem to find a definitive answer either way. When I select TTL on the flash, I just see a blinking A. Wondering if I am not choosing the right settings on my camera or if it’s simply not supported. Anyone have any luck on a Q2 or a Q3? If so, can you please tell me what I’m doing wrong? Thank you! Link to post Share on other sites More sharing options...
Advertisement Posted June 21, 2023 Posted June 21, 2023 Hi Mink, Take a look here TTL possible w/ 24D Flash on a Leica Q3? . I'm sure you'll find what you were looking for!
Ozymandias Posted June 21, 2023 Share #2 Posted June 21, 2023 Hello Mink, Sorry, I can't answer for the 24D, but I have a (similar vintage) SF26, and that does work with TTL on the Q3. One thing though, the SF26 is really difficult to get onto the hot shoe of the Q3 - even harder to get off. If it's not seated all the way in, it seems to not sync correctly with TTL and other settings. Maybe the 24D has similar issues? Seems the mounting foot on these earlier Leica flash units were slightly larger than the current flashes such as the SF40 that I also have, and slips into the Q3 shoe quite easily. Paul Link to post Share on other sites More sharing options...
Mink Posted June 22, 2023 Author Share #3 Posted June 22, 2023 Thanks Paul. I thought about getting the SF26 but I got a deal on a 24D. Im looking at the set up and the 24D slides in easily and locks in. I don’t really see anymore room for it to go in. Could be a different issue or just incompatible for TTL Curious if you need to set anything on camera to make your SF26 work or do you just switch on TTL on the flash? Thanks for the advice. cheers, min Link to post Share on other sites More sharing options...
Ozymandias Posted June 22, 2023 Share #4 Posted June 22, 2023 6 hours ago, Mink said: Thanks Paul. I thought about getting the SF26 but I got a deal on a 24D. Im looking at the set up and the 24D slides in easily and locks in. I don’t really see anymore room for it to go in. Could be a different issue or just incompatible for TTL Curious if you need to set anything on camera to make your SF26 work or do you just switch on TTL on the flash? Thanks for the advice. cheers, min Hello Mink, I just set the TTL mode/switch on the SF26 - don't use the inbuilt diffusers - and generally the flash exposure is pretty good. Having said that, the SF40 is a more versatile flash unit, but by having both I can set the SF40 in slave mode off camera and it can be triggered by the SF26 on camera to get a more balanced (light) result. I like using the smaller SF26 however, as it looks less obtrusive on the camera, and for daytime fill flash it is simple to set up and use. Paul Link to post Share on other sites More sharing options...
Mink Posted June 22, 2023 Author Share #5 Posted June 22, 2023 1 hour ago, Ozymandias said: Hello Mink, I just set the TTL mode/switch on the SF26 - don't use the inbuilt diffusers - and generally the flash exposure is pretty good. Having said that, the SF40 is a more versatile flash unit, but by having both I can set the SF40 in slave mode off camera and it can be triggered by the SF26 on camera to get a more balanced (light) result. I like using the smaller SF26 however, as it looks less obtrusive on the camera, and for daytime fill flash it is simple to set up and use. Paul Guessing this means I either 1) have a lemon or 2) TTL is not available for the Q3 using the 24D. When I set mine to TTL, I get a blinking A on the flash display. Thanks for the advice! Link to post Share on other sites More sharing options...
Tomas Eriksson Posted August 7, 2023 Share #6 Posted August 7, 2023 I just picked up a SF24D, it works in TTL mode together with my Q2. Unfortunately I don't know anyone here in Stockholm with a Q3 to test it's compatibility with Link to post Share on other sites More sharing options...
petrvagner Posted August 23, 2023 Share #7 Posted August 23, 2023 Advertisement (gone after registration) Hello, same problem with Q3 as stated above with the A blinking. I worked on Q2, does not work on Q3 right now. Maybe a firmware fix? Link to post Share on other sites More sharing options...
jaapv Posted August 23, 2023 Share #8 Posted August 23, 2023 Quite apart from the original question, I think that the SF 26 is horribly overpriced compared to the SF 40 which is not cheap itself either. As an alternative , especially for fill or trigger, a used SF 24 D is an excellent choice. Link to post Share on other sites More sharing options...
adrianh Posted August 23, 2023 Share #9 Posted August 23, 2023 Try to NOT tighten up the shoe and have it NOT pushed completely in (push completely in than pull out 1mm) Link to post Share on other sites More sharing options...
activeuk Posted September 8, 2023 Share #10 Posted September 8, 2023 does the sf24 work with the q3 just got one and can not get ttl to work Link to post Share on other sites More sharing options...
Michon Posted September 27, 2023 Share #11 Posted September 27, 2023 I have the rxact same compatibility problem with my Q3 and my SF24D in TTL mode. I sent an email to the Leica support team 2 week-end ago and today the french tech manager called me and confirmed that the german techs sauf that the Q3 is supposed to be compatible with the SF24D in TTL mode. He suggested me to make another test after a reset of the camera and/or to come back to him after the next firmware upgrade if he the problem is still not fixed. Let's wait for the next firmware release that should happen vers quickly accirding to the french Leica team. 1 Link to post Share on other sites More sharing options...
Michon Posted September 28, 2023 Share #12 Posted September 28, 2023 I just finished the uprade to the Last 1 3 version and made some tests. I confirm that TTL mode of rhe SF24D does not work with the Q3 despite Leica Germany has confirmed yesterday the full compatibility betwern Q3 and flash SF24D. The problem is: When I select TTL on the flash, I just see a blinking A. on the flash screen. If you have rhe solution or if you don't have any problem with SF24D flash and your Q3, could you you please communicate ? If you have the same problem, I suggest to inform the Leica support team at the following email address: customer.care@leica-camera.com The more customers will complain the soonest the fix will be provided. Link to post Share on other sites More sharing options...
lefse Posted March 10, 2024 Share #13 Posted March 10, 2024 On 9/28/2023 at 11:37 PM, Michon said: The more customers will complain the soonest the fix will be provided. I just sent customer care an email asking about this. Hopefully the reply will be that they’re working on a fix. Anyone else got some news regarding this? Link to post Share on other sites More sharing options...
lefse Posted March 18, 2024 Share #14 Posted March 18, 2024 On 3/10/2024 at 2:24 PM, lefse said: I just sent customer care an email asking about this. Hopefully the reply will be that they’re working on a fix. Anyone else got some news regarding this? Customer care just came back to me with this: Quote Indeed, the SF 24D is not compatible and the SF 26 neither. You may use the SF 40, SF 64, SF 60 and SF C1. 1 Link to post Share on other sites More sharing options...
nicci78 Posted March 18, 2024 Share #15 Posted March 18, 2024 (edited) This Q3 technical data : no mention of SF24D Flash exposure compensation only available with SF40 and SF60 Flash Flash unit connector Via the accessory shoe Flash sync time 1/2000 s, slower shutter speeds available, an automatic changeover to TTL linear flash mode with HSS-compatible Leica system flash units if sync time is undercut Flash exposure metering Using center-weighted TTL pre-flash metering with Leica flash units (SF 26, SF 40, SF 58, SF 60, SF 64) or with system compatible flash units, remote-controlled flash SF C1 Flash exposure compensation SF 40: ±2 EV in 1/2 EV increments SF 60: ±2 EV in 1/3 EV increments Edited March 18, 2024 by nicci78 Link to post Share on other sites More sharing options...
