I had tried that but not in real use,
as M3 VF+ RF is fine for 90mm Summicron not needing the add-on 1.25/1.4 mag.
Plenty enough RF accuracy,  even wide open use.
For Elmarit 135mm, Leitz cleverly used the 90 field in VF and adding x1.5 optical device.
from v I to v III
from v I to v III
Thanks, I suspected as much, but was curious. Yes, the Elmarit is truly something!
