onogawa Posted November 8, 2007 Share #1 Posted November 8, 2007 Advertisement (gone after registration) While rewinding film on my Leica M6 i exprience resistance which makes the rewinding crank very stiff. Though i succeed to have the film back in the cassette, still it seems that it is to much of ressistance and on long run may result even in damage. I do all as need to be done as i used leica M3 , M2 and M4 without such problem. Could be my camera has foult - yet it was inspected by repairman, said no problem. Link to post Share on other sites More sharing options...
Advertisement Posted November 8, 2007 Posted November 8, 2007 Hi onogawa, Take a look here Leica M6 rewind mechanism stiff. I'm sure you'll find what you were looking for!
kodaktrix Posted November 9, 2007 Share #2 Posted November 9, 2007 Josef, I use a M6TTL, M2 and M3 for years now. I too notice that rewinding the M6TTL is remarkable stiffer than rewinding the M2/ M3. Never had problems of damaged film. Regards Oliver Link to post Share on other sites More sharing options...
doubice Posted November 10, 2007 Share #3 Posted November 10, 2007 Josef, The spindle that is attached to the base plate of your M6 (not sure exactly what it might be called - the one that pushes the film down onto the M6's take-up spool), adds resistance to the whole rewind process. Make sure that this spindle is not binding and providing more resistance than usual. I have had this happen to me - switched baseplates from an M4 to an M6, the spindles did not match just right, et voilà - rewind got much stiffer. Best, Jan Link to post Share on other sites More sharing options...
onogawa Posted November 10, 2007 Author Share #4 Posted November 10, 2007 thanks so much for response. in that case i will go along with my leica m6 as it is,though i wonder how it will be when i'll attach the m6 motordrive which i consider to purchase in the future. Link to post Share on other sites More sharing options...
leitz_not_leica Posted November 11, 2007 Share #5 Posted November 11, 2007 Did you drop the camera on its end. I did once with my M4 and the RW knob bent into the body. The knob had to be replaced. Link to post Share on other sites More sharing options...
gyoung Posted November 12, 2007 Share #6 Posted November 12, 2007 Did you drop the camera on its end. I did once with my M4 and the RW knob bent into the body. The knob had to be replaced. Same thing happened to me on M6ttl, the knob/crank assembly bent and was catching on the top housing. Malcolm Taylor straightened it whilst checking the camera over and adjusting the rangefinder. I thought the shaft had bent but he says that is very strong, he has never seen one bent. Gerry Link to post Share on other sites More sharing options...
onogawa Posted November 13, 2007 Author Share #7 Posted November 13, 2007 Advertisement (gone after registration) it did not fell down but it is second hand body so i do not know before. it was send to Don Goldberg but he returned it saying it is ok, but still the rewinding remains very stiff, contrary to my previous body - much older but very easy rewind, also my m3 is so easy to rewind. Link to post Share on other sites More sharing options...
doubice Posted November 14, 2007 Share #8 Posted November 14, 2007 it did not fell down but it is second hand body so i do not know before. it was send to Don Goldberg but he returned it saying it is ok, but still the rewinding remains very stiff, contrary to my previous body - much older but very easy rewind, also my m3 is so easy to rewind. Josef, If Don Golberg says it's OK, than it must be OK. There are not too many better Leica technicians on this side of the Atlantic....... Best, Jan Link to post Share on other sites More sharing options...
