grahamc Posted April 23, 2023 Share #1 Posted April 23, 2023 Advertisement (gone after registration) Hi. I can't find a definitive answer whether IR dust removal works when scanning on the Plustek , using Vuescan (RAW / DNG) and then NLP for conversion. I understand dust removal should work if 'RAW output to' is set to 'SAVE'. Any experiences/recommendations from members here with the same process flow, please? And if you are using IR cleaning Vuescan are you using mild/medium/strong ? So far I can't see the clean actually doing anything, although I think my negs that appear dusty might have some processing issues rather than actually being dusty. I'd still like to know whether the IR in Vuescan plays well with Plustek > RAW > NLP though for future reference. Thanks Graham Link to post Share on other sites More sharing options...
Advertisement Posted April 23, 2023 Posted April 23, 2023 Hi grahamc, Take a look here IR Dust Removal (Plustek 8200Ai , Vuescan Raw DNG + Negative Lab Pro) . I'm sure you'll find what you were looking for!
frame-it Posted April 23, 2023 Share #2 Posted April 23, 2023 (edited) On plustek via silverfast scanning as Tiff, it works fine, i usually make a small mask around the area i want to clean, set it to 18 i don't use vuescan, but i know in silverfast if i scan as raw[dng] everything is automatically off, so IR/curves/NR etc etc will not work because its making a raw file Edited April 23, 2023 by frame-it 1 Link to post Share on other sites More sharing options...
grahamc Posted April 24, 2023 Author Share #3 Posted April 24, 2023 (edited) 17 hours ago, frame-it said: On plustek via silverfast scanning as Tiff, it works fine, i usually make a small mask around the area i want to clean, set it to 18 i don't use vuescan, but i know in silverfast if i scan as raw[dng] everything is automatically off, so IR/curves/NR etc etc will not work because its making a raw file Thanks - yes on Vuescan apparently nothing works in RAW also , with the exception that if you tick ' RAW file to "SAVE" ' then apparently IR works. I can't see that it is working , which is why I posted this thread. but I could be wrong. I might also try a tiff (for which IR works of course) to see a point of reference for comparison and whether the IR is working in raw. Edited April 24, 2023 by grahamc Link to post Share on other sites More sharing options...
