neonvoid Posted April 15, 2023 Share #1 Posted April 15, 2023 (edited) Advertisement (gone after registration) New M11, purchased a couple of days ago, has a vertical misalignment that is apparent from ~3m to infinity, but at closer ranges seems to be aligned OK, or at least not very noticeable. Doesn't sound like something a simple twist of a screw can fix, because the offset changes relative to the focusing distance. From your experience, is my only option shipping it to Germany for calibration, even though it's a new one? Edited April 15, 2023 by neonvoid Link to post Share on other sites More sharing options...
Advertisement Posted April 15, 2023 Posted April 15, 2023 Hi neonvoid, Take a look here Vertically misaligned rangefinder on M11. I'm sure you'll find what you were looking for!
dpitt Posted April 15, 2023 Share #2 Posted April 15, 2023 (edited) Vertical alignment can also change with the angle of view (that is actually normal for a RF). Did you hold the camera perfectly horizontal on all tests? Edited April 15, 2023 by dpitt Link to post Share on other sites More sharing options...
neonvoid Posted April 15, 2023 Author Share #3 Posted April 15, 2023 5 minutes ago, dpitt said: Vertical alignment can also change with the angle of view (that is actually normal for a RF). Did you hold the camera perfectly horizontal on all tests? Yes, I also have an MP which I can compare the M11 rangefinder to. In the M11 it’s misaligned consistently when held perfectly horizontally and doesn’t get better when rotating the camera left/right a bit. Link to post Share on other sites More sharing options...
Photoworks Posted April 15, 2023 Share #4 Posted April 15, 2023 Sounds like a return or exchange is the only option if you don't want to send it in for calibration. Link to post Share on other sites More sharing options...
hdmesa Posted April 16, 2023 Share #5 Posted April 16, 2023 15 hours ago, neonvoid said: New M11, purchased a couple of days ago, has a vertical misalignment that is apparent from ~3m to infinity, but at closer ranges seems to be aligned OK, or at least not very noticeable. Doesn't sound like something a simple twist of a screw can fix, because the offset changes relative to the focusing distance. From your experience, is my only option shipping it to Germany for calibration, even though it's a new one? My first M11 had a vertically misaligned rangefinder as well. No way in hell I was going to wait for a repair on a brand new $9K camera. A new camera should be perfect. Exchange it. Link to post Share on other sites More sharing options...
