nikrasov Posted March 24, 2023 Share #1 Â Posted March 24, 2023 Advertisement (gone after registration) Hi! In manual said that one should set B/Off on Leica MP when not in use to prevent battery leaking. Is this leaking only happens when shutter button pressed/half pressed or always when B/Off is not selected? Should I always set to B/Off when the camera is on shelf? Link to post Share on other sites More sharing options...
Advertisement Posted March 24, 2023 Posted March 24, 2023 Hi nikrasov, Take a look here Should set B/Off on Leica MP when not in use. I'm sure you'll find what you were looking for!
250swb Posted March 24, 2023 Share #2 Â Posted March 24, 2023 B/Off is to stop the battery draining if you have the camera in a bag and the shutter button is touching the sides of the bag. For normal use you don't need to keep switching it off as it will switch off on its own if you are not touching it. Link to post Share on other sites More sharing options...
LocalHero1953 Posted March 24, 2023 Share #3 Â Posted March 24, 2023 And it is only necessary if you have wound on. The meter is off anyway if you have not wound on. 1 Link to post Share on other sites More sharing options...
atournas Posted March 24, 2023 Share #4 Â Posted March 24, 2023 (edited) When at B/Off, you avoid battery draining, but no battery leaks; however, if you leave the camera at B/Off for a long time, say three months or more, then you increase the risk of leaks. In practice, things are simpler: Switch off the camera when not in use, but use it regularly. Of course, the best solution is not to use a light meter. No batteries, no worries! Edited March 24, 2023 by atournas 1 Link to post Share on other sites More sharing options...
Mikep996 Posted March 25, 2023 Share #5  Posted March 25, 2023 "Of course, the best solution is not to use a light meter. No batteries, no worries!" Yeah, I'm still annoyed that cars went to that danged battery/starter thing instead of the hand crank.  🙄 1 7 Link to post Share on other sites More sharing options...
nikrasov Posted March 25, 2023 Author Share #6 Â Posted March 25, 2023 Thank you all for the useful tips! Link to post Share on other sites More sharing options...
Huss Posted March 26, 2023 Share #7  Posted March 26, 2023 Advertisement (gone after registration) If Leica says to turn it off to B when not in use, do that.  They engineered and built the camera. If you are storing the camera,  remove the batteries. From the Leica manual: BATTERY • Always remove the battery if the camera will not be used for an extended period of time. 3 Link to post Share on other sites More sharing options...
