Maybe a solution for the M8 bottom plate
MitchoIankov
I have read that Eye-Fi Card Review: 1. Introduction: Digital Photography Review today and it looks like a good workaround the bottom plate remove/put back at least when not many images are taken.
I am a bit annoyed every time when I have to take the bottom plate off to upload the images to the PC. Some times it is only one or two. Is it only me?
x
I think the OP means that since the Eye-Fi is basically an SD memory card with built-in Wi-Fi, it will be handy to transfer a few shots at a time to a computer without having to remove and replace the bottom plate all the time.
I'm curious as to just how well Wi-Fi is going to work through that metal bottom plate, though.
Yes, I was wondering if it'd work through the brass bottom plate, too.
The other thing I was wondering about this product was the write speed of the flash ram itself. The product's website doesn't mention it at all, which leads me to believe that it's on the slow side.
The M8 isn't on the list of compatible cameras, anyway.
John
Since the card will include a WiFi transmitter and use more power than a non-WiFi SD card most of the additional power will be converted into heat energy.
I wonder whether the additional heat would affect the M8's operation, or perhaps worse, affect the warranty.
Pete.
Pete.
My first thought when reading about it wasn't the heat but could it provide interference with the circuitry or in capturing the image while shooting right around the wifi hot spot.
It's a nice idea in theory, but as others have pointed out, the whole construction of the M8 is designed for EMC Compatability - to stop it radiating RG energy and causing interference, so at least some attenuation of the signal would take place. Other cameras with WiFi adapters have an external aerial/antenna.
The other issue is battery power. Having the WiFi adapter on all the time is bound to drain the battery faster which will mean you will have to take the bottom plate off to change it anyway.
I had hoped for a series of alternative base-plates for the M8 - additional battery, Wi-Fi, Docking/Charger.
well I wonder if dealing with wifi would be all that much easier than twisting a piece of metal and removing the plate. you could even do it when you change the battery-which there is no workaround for that I know of. i don't mind the plate myself and like other above I kind of like it...b
Guest tummydoc
I join with the sensible minds who chuckle at the notion removing the bottom-plate represents a major inconvenience worthy of a workaround. I don't see how it's much more of a bother than flipping open a hatch, and even if one only shoots 36 of the possible 180 DNGs at a time on a 2GB SD card, one wouldn't be removing the bottom any more often than one would if changing films in an M7.
There are few things in the midst of shooting that I just as soon not have to do as remove and replace the baseplate on the M8. I appreciate the design of the camera and Leica's efforts to keep it largely consistent design-wise with previous models. But really, what purpose does it serve? I'd rather have a SD card slot and a little trap door for exchanging the battery quickly when I'm photographing people. The less hassle, the better.
