M8 in the tropics - no problem with camera, but red lens buttons dropped off...
chris_tribble
The good news is that both M8s are doing well in a wide range consultancy around Sri Lanka.
The annoyance is that the red buttons on 2 lenses have fallen out and got lost. Does anyone know if it's possible to get these little red plastic blob that helps you line up the bayonet when mounting the lens? I've just lost two -- one from the 35 (v4) cron and the other from my 28 cron Asph. I'm in the tropics in Sri Lanka at the moment, and the heat must have unglued them...
Grateful for any advice.
Best
x
Chris, I think Leica UK will send you replacements foc, especially if you lay it on a bit thick with tales of daring-do and how you wrestled the lens from the grip of an orang-u-tang.
If not, I think they are a boggling £5 each...
You can re-glue having removed any traces from the recess, using the smallest drop of super-glue (to stop it coming out at the edges).
Mark - many thanks
No orang-utans, but wild and grumpy elephants, yes. Evidence attached. M8 + 135 Apo Telyt, late evening light, 640 ISO fully open 1/125th .
V Best
Chris,
A 'Blue Peter' moment: if you're unable to obtain the bona fide Leica red buttons then you can use map pins with the circular heads by cutting them in half and gluing them in place. Yes, it works and it's hard to tell the difference. (No sticky-backed plastic required.:o )
And if you're the adventurous type who will never part with his lenses then you could colour code your lenses with different coloured pins. Who knows, it might increase their value in years to come: "This lot comprises the rarest of Leica 35/f2 Summicron aspherical lenses which sports a yellow button in place of the common red button. This is the only known example, dating from circa 2007. We start the bidding at £100,000 ... £100,000 to Bill Gates III in the hologram at the rear ... do I have £120,000 ... ?"
(Of course by then a loaf of bread will cost £5,000. :D )
Pete.
Guest guy_mancuso
Mark - many thanks
V Best
Who says you need longer than 135:D
Just make sure the peanuts are 200 ft out first. LOL
Nice one Chris
Pete.
I believe you but...er...how do you cut the beads in half? Is it like, "First you buy a table saw with a micrometer attachment?"
JC
EVEN - The Classic Camera Shop in London will give you one despite their "urban legend" unhelpfulness - which I think is, unfortunately for them, overstated.
Lovely ephlewaunt pictures Chris - enviable assignment!
JC
Nothing as exotic as that, John, I simply used a pair of locking pliers to hold the pin and used a small fretsaw blade - gently at first to start the cut. For good measure I used a large round file to approximate the contour at the back of the bead to the curvature of the lens barrel and epoxied the result to my 90 Elmarit, where it firmly stayed until the Elmarit committed lensicide over a cliff in the Canadian rockies earlier this month.:(
Of couse, now that I know Leica will supply the real article ...
Pete.
Well, the other thing that is red all the way through is a knitting needle. Bit of work, but it gives you an endless supply. The only thing is you will probably only need to glue things on once....whereas Leica....
Wouldn't the knitting needle catch on your clothes while you're changing lenses, Rob? :rolleyes:
And how would you finish those woolly socks for Aunt Gemima's birthday with only one needle left? Do you know any one-armed knitters to give you some tips?
Pete.
Mark - many thanks
V Best
I've been using M lenses in Singapore for years. Nothing has fallen off yet :-)
