Hello, was wondering if anyone could help me with this rather large light leak with my M3, anyone know why and how to fix it..?! Its doing my head in ! Thank you very much !
Maybe a hole in the shutter curtains? If so the leak will depend on the amount of time you take between advancing the film and shooting the shot.
This is consistent with the 2 bottom shots. First the bottom one, and then re frame and take shot 2, which is not showing the light leak.
Edited by dpitt
That's definitely not a hole in a shutter curtain.  That hard edge shows it is a light leak elsewhere - maybe through the VF or back door.  I had a smaller version of that, but the same shape, and it was through the right side RF window.
I had a similar issue and it was a hole in the shutter .
I think it's from the viewfinder.  It's the same conical shape that appears erratically on my M5 negatives.  There may not be pattern, either.  Sun direction, shutter speed, etc, seems not to matter.
4 hours ago, Huss said:
A hole in the shutter does not have a light leak shape like that.
The leak I was referring to showed with  a horizontal hard edge and was placed nearer to the lower edge of frame , on a MP body.
Let's hope the OP finds out what causes the leak !
Edited by JMF
Now I'd like to ask about a leak I have, as well on a M3 !
It is consistently (just shot 2 rolls) in the lower left spot with this oblong shape, most of the time dimmer than in the photo below.
It does not bleed on the interimage so I'm with the feeling it comes from a shutter blind hole.
Any advices are welcome and appreciated !
Thank you
Best
JM
Edited by JMF
I had simular issues one was the film Lab, the other was the actual film roll itself, and last a leak in my shutter curtain, it's an act of Science trying to figure out who's at fault, I couldn't  sleep for days
