Natty Posted February 16, 2023 Share #1  Posted February 16, 2023 Advertisement (gone after registration) I recently purchased a brand newLEICA MA, and noticed the shutter speed dial feels a bit wobbly; as in when it's locked to a desired shutter speed, you can still fiddle (left to right) on the dial with ur finger (when it should be fully static/locked), is that normal, I have an M6 & and an MP, none of them display such issue Link to post Share on other sites More sharing options...
Advertisement Posted February 16, 2023 Posted February 16, 2023 Hi Natty, Take a look here Wobbly shutter speed dial. I'm sure you'll find what you were looking for!
JT73 Posted February 16, 2023 Share #2  Posted February 16, 2023 It’s nothing to worry about, there are always slight variations between bodies. You can try slightly tightening the screw on the top of the dial, it should take out some of the play if it bothers you. 1 Link to post Share on other sites More sharing options...
wattsy Posted February 16, 2023 Share #3 Â Posted February 16, 2023 Yes, I imagine the little screw is slightly loose. Easy to tighten with an appropriate fitting screwdriver, 1 Link to post Share on other sites More sharing options...
69xchange Posted February 16, 2023 Share #4  Posted February 16, 2023 (edited) 10 hours ago, Natty said: I recently purchased a brand newLEICA MA, and noticed the shutter speed dial feels a bit wobbly; as in when it's locked to a desired shutter speed, you can still fiddle (left to right) on the dial with ur finger (when it should be fully static/locked), is that normal, I have an M6 & and an MP, none of them display such issue There was no play in my MP or M-A. But my new MP had a very stiff and crooked rewind knob (not too big of concern). Just sent the new MP back due to faulty light meter, so I’ll check my next one that arrives. Edited February 16, 2023 by 69xchange Link to post Share on other sites More sharing options...
Huss Posted February 17, 2023 Share #5 Â Posted February 17, 2023 No, there should be no play. Â There is zero play on my M-A. Â As others have mentioned, try tightening that little screw on it. Link to post Share on other sites More sharing options...
69xchange Posted September 2, 2023 Share #6  Posted September 2, 2023 I also had a loose shutter speed dial and it was moving every time I fired the shutter. I had to take the shutter speed dial off and tighten the cross/ Philips screw as seen in this picture. This fixed my issue. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/366902-wobbly-shutter-speed-dial/?do=findComment&comment=4848573'>More sharing options...
250swb Posted September 2, 2023 Share #7  Posted September 2, 2023 Advertisement (gone after registration) It's a brand new camera so this is a 50/50 decision whether to be slightly brave or return it, I would imagine returns generate reports to Leica about what they've screwed up otherwise they'll never know. So if you go ahead be sure to use the exact size screwdriver for both the screw on the dial and the screw underneath. But it's good to see a forum member @69xchange just getting on and doing a simple job. Outrage is always caused if advocating DIY jobs on Leica's and there seems to be a fetish for sending them back, so for the record no it shouldn't be loose, but life is what it is and a good set of screwdrivers is empowering. 1 Link to post Share on other sites More sharing options...
