LeicaS2 Posted August 29, 2023 Share #21  Posted August 29, 2023 Advertisement (gone after registration) OK Tangosix, here’s a 90mm heavily cropped because I hadn’t received my Leica 100-400.  Frankly the 90 is so good, the only reason to use the 100-400 is if you need the resolution for huge enlargements. The heat waves will be the bigger issue on long shots, not the optics.  If I were traveling, the 90mm can replace the 100-400. I have not tested it against the 70-290. But the 70-290 is not a walk around lens for me. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 5 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/364913-sl-90mm-apo/?do=findComment&comment=4846271'>More sharing options...
Advertisement Posted August 29, 2023 Posted August 29, 2023 Hi LeicaS2, Take a look here SL 90mm APO. I'm sure you'll find what you were looking for!
