Removing the Base Plate Label
marknorton
I realised last night how much I hate the "appliance" label on the bottom of the camera which makes it look like a vacuum cleaner. If mobile phone manufacturers can put this regulatory nonsense inside a removeable cover, why can't Leica?
I mean, as if anyone is going to dispose of their M8 in landfill....
So, using a soft wooden spatula and a finger-nail and some patience, it's easy to remove the plastic film and the regulatory label. I decided to keep the standard base-plates "original" and removed the label from the grips I use on each camera instead.
They look so much better as a result. Sure, there will be some wear and tear in the future but if it matters, you can always buy a new one for much less than a replacement base plate bought as a spare part.
Removing the film and especially the label may leave some residual goo. I used a de-greaser intended for cleaning car engine parts called "Jizer" to remove it which has the advantage of being water miscable so you can rinse it off with a mild detergent and hot running water. Best not to immerse it because water will get inside the grip handle. You can buy it at Amazon, otherwise you can use another organic solvent to remove the residue.
There's a feeling of liberation when you do it, and if the base gets scratched, hey, that's just me enjoying the camera.
Oh Mark, what took you so long? I removed them while charging the battery.:D
These labels are indeed disgusting looking things. On anything, not just cameras. The ones I hate most are the ugly yellow ones on my car's sun visor warning about the air bags. Do you have a way to remove these? The labels, not the bags.
At least when you live in Toronto you don't need a counsel. (Joking of course).
Guest tummydoc
Perhaps on the same grounds that they cited for denying us a lens-recognition menu, protection from our own feeble-mindedness :rolleyes:
I've heard eBay called worse names than that :D
So, using a soft wooden spatula and a finger-nail and some patience...{blahblahblahblah]...otherwise you can use another organic solvent to remove the residue.
Good lord, a 1000-word essay on peeling-off a bloody baseplate sticker :confused:
Certainly in my case removing the plastic cover when it had become marked left a lot of sticky 'gunk' behind. I used lighter fluid to remove it, Mark's post is offering some good advice to anyone who wants to remove the base, so perhaps a little less sarcasm would be in order Vinay.
