jmp Posted January 15, 2023 Author Share #21 Â Posted January 15, 2023 Advertisement (gone after registration) Unfortunately, I don't have access to any M240 Link to post Share on other sites More sharing options...
Advertisement Posted January 15, 2023 Posted January 15, 2023 Hi jmp, Take a look here Canon 28mm 2.8 LTM focusing issue. I'm sure you'll find what you were looking for!
Pyrogallol Posted January 15, 2023 Share #22 Â Posted January 15, 2023 (edited) It does sound as if it has been taken apart and reassembled wrong. I think you should return it if you can. I have had one or two eBay purchases with similar problems that I have returned. Edited January 15, 2023 by Pyrogallol Link to post Share on other sites More sharing options...
jmp Posted April 8, 2023 Author Share #23  Posted April 8, 2023 Update: I have managed to fix the problem. Indeed the issue was coming from a wrong reassembly of the rear helicoid (the one driving the telemeter). After a bit of try and test, I managed to find the right spot and now infinity is on focus when on the infinity lock and distances are right on the focus ring. For the record, I have also found some informations on old Canon lenses where the infinity can be finely tuned using an inner shim. I have tried this method but my lens' shift was too large to be fixed like this. But the method is valid for smaller shift. check here (in Japanese)  https://mglss.rakugan.com/ While opened, I also took the opportunity to make a good cleaning and lubing, so it's almost as good as new    1 Link to post Share on other sites More sharing options...
