Yellow_78 Posted January 5, 2023 Share #1 Posted January 5, 2023 Advertisement (gone after registration) Hi all, I love my SL2s and the lenses with it but was just wondering if anyone else is experiencing the rubber rings turning whitish? I look after my gear well and they live in a dehumidifeid cabinet when not in use. Any recommendations on how to treat/prevent this?? Thanks in advance! Link to post Share on other sites More sharing options...
Advertisement Posted January 5, 2023 Posted January 5, 2023 Hi Yellow_78, Take a look here SL lenses rubber focus rings turning white? . I'm sure you'll find what you were looking for!
helged Posted January 5, 2023 Share #2 Posted January 5, 2023 6 minutes ago, Yellow_78 said: Hi all, I love my SL2s and the lenses with it but was just wondering if anyone else is experiencing the rubber rings turning whitish? I look after my gear well and they live in a dehumidifeid cabinet when not in use. Any recommendations on how to treat/prevent this?? Thanks in advance! 1 Link to post Share on other sites More sharing options...
frame-it Posted January 5, 2023 Share #3 Posted January 5, 2023 why don't you post a photo so people can see what happened exactly? 1 Link to post Share on other sites More sharing options...
andybarton Posted January 5, 2023 Share #4 Posted January 5, 2023 Small poll, I know, but both these examples involve dehumidifier cabinets. 1 Link to post Share on other sites More sharing options...
Yellow_78 Posted January 5, 2023 Author Share #5 Posted January 5, 2023 4 hours ago, helged said: Thanks for sharing! I'll give the old toothbrush and water solution a go, cheers! 1 Link to post Share on other sites More sharing options...
Yellow_78 Posted January 5, 2023 Author Share #6 Posted January 5, 2023 4 hours ago, frame-it said: why don't you post a photo so people can see what happened exactly? Good idea. I'll post a pic when I get time but it basically looks like that 90mm in the example above! Link to post Share on other sites More sharing options...
AndreasG Posted January 5, 2023 Share #7 Posted January 5, 2023 Advertisement (gone after registration) Rub it off with a wet cloth (water + 3% glycerol). This was successful with my Hasselblad/Zeiss lenses. Link to post Share on other sites More sharing options...
LBJ2 Posted January 8, 2023 Share #8 Posted January 8, 2023 On 1/5/2023 at 4:37 AM, Yellow_78 said: Hi all, I love my SL2s and the lenses with it but was just wondering if anyone else is experiencing the rubber rings turning whitish? I look after my gear well and they live in a dehumidifeid cabinet when not in use. Any recommendations on how to treat/prevent this?? Thanks in advance! This happens to a few of my lenses but not all equally used lenses. Not sure why. I keep a dry toothbrush ready just for this. I just give the rubber-like focus ring a brisk dry brush a couple of times over and that does the trick, I finish with a rocket blower just incase there is any dry residue left after the brushing. I don't use any type of liquid, alcohol or any solution. From what I have experienced, once it starts on one lens it seems to happen again on the same lens from time to time--must be some breakdown in the material.. But the toothbrush alone seems to be the solution. 1 Link to post Share on other sites More sharing options...
Yellow_78 Posted January 9, 2023 Author Share #9 Posted January 9, 2023 1 hour ago, LBJ2 said: This happens to a few of my lenses but not all equally used lenses. Not sure why. I keep a dry toothbrush ready just for this. I just give the rubber-like focus ring a brisk dry brush a couple of times over and that does the trick, I finish with a rocket blower just incase there is any dry residue left after the brushing. I don't use any type of liquid, alcohol or any solution. From what I have experienced, once it starts on one lens it seems to happen again on the same lens from time to time--must be some breakdown in the material.. But the toothbrush alone seems to be the solution. Thanks for your suggestion! Will try this first before the solution method. Haven't had a chance to try anything yet but hopefully soon. 👌 1 Link to post Share on other sites More sharing options...
leicamr Posted January 9, 2023 Share #10 Posted January 9, 2023 I believe that the white is salt deposit from moisture in handlers hands / fingers. Mark 1 Link to post Share on other sites More sharing options...
akiralx Posted January 17, 2023 Share #11 Posted January 17, 2023 Yes this happened also to my 75mm Summarit-M - a careful few minutes with a barely damp old toothbrush seemed to solve it, though it's never going to look as black as the (metal) aperture ring just above it. Link to post Share on other sites More sharing options...
