Dust spots inside lens - clean worth while?
citrus
My WATE has three visible dust spots inside the lens barrel - no idea how they got there. I am not sure if they will appear on the pictures when shooting at f16 - I think it will harm the picture somewhat in any case, or?
I see dust on the sensor easily - but does dust inside the lns also get visible - I do not think so, but I hve seen people in the forum that say it does. As I have no way to compare I dont really know what to think.
How much is lens cleaning at Leica anyway - anybody have some xperience?
Guest darkstar2004
Dust inside a lens is irritating, but I have never seen it cause any negative results on the photographs made with those lenses.
Seems like it could possibly be an issue if you were photographing into a bright light source; you might want to give that a try and see what results you get. Also, try photographing a clear blue sky - use E6 film for both tests.
If neither test produces problems, try to not worry about the dust. Dust inside a lens is pretty much inevitable, unless you buy a lens, never open the box and seal it up in shrink wrap.
