thinking of putting a monopod on my M8
usccharles
anybody use monopods on their M8? any recommendations?
i do alot of available light shooting with my nocti and 75/lux, and considering a monopod to keep my camera steadier in slow shutter speeds.
is there a monopod that i can just fold up while walking and be able to easily pull out to the desired length, like a one-button mechanisim? not really into the monopods with the multiple clamps that you have to loosen and tighten everytime you want to extend.
thanks in advance ;)
Charles,
I use the Leki Sierra Photo, which doubles as a trekking pole. It is OK but would be improved by a mini ball head, which I may get next year for it. The pole telescopes down to about 60 - 70 cm.
Wilson
I have a Gitzo Monotrek G1560 - which is in aluminium and virtually indistinguishable from a collapsible ski-pole / hiking stick with a sling for the hand, spike, snow-disc and all. I am not entirely happy with the flimsy ball head it comes with so I consider switching to the Gitzo G1077M which is a bit more heavy-duty. Having no washer between the camera and the head - the original ball head also leave a circular mark on your bottom plate. I do not care - my cameras are for use, not for show. But some might find this off-putting.
thank you for all you messages. i will look up all your suggestions. i'm not much of a hiker. just mainly street shooting, but i like shooting at night when everyone has gone home and there are nothing but cats, street lights, and the remains of a busy day.
i looked up manfrotto and they had a couple with an easier extend method:
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/2374?livid=107|117&idx=119
334B
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/3356?livid=107|117&idx=119
685B
any experiences with these?
thanks again ;)
I have a Gitzo GM2560T "mini"....35cm when retracted and 145cm fully extended (minus the head, also a Gitzo, G1077M). It goes nicely into a small backpack if your'e travelling light. Good quality but a bit on the pricecy side and you sacrifice a bit of length for the convenience...!!
Leica's mini-tripod with ball head (and Bogen Manfrotto makes a lesser cost mini-table top tripod too) used as a chest-pod (braced on your chest for stability) may be a more compact solution to hold your rig steady.
Here's the Bogen Manfrotto at B&H, all folds flat into a nice small bag:
Bogen / Manfrotto | 3007 Tabletop Tripod Kit with 482 | 3007KIT
Adorama makes a knock off of the old Linhof Monomatic monopod called the Podmatic for less then half the price.
If there ever was a monopod made for the M this is it. Lightweight 5 section monopod with 1 step quick open/close. Closed it's 14 inches extends to 58 1/2". Nothing I've seen is anywhere near as fast opens and locks to any position instantly -closes just as fast.
Pop a Bogen model #3232 (Manfrotto #234) swivel head and Arca clamp on it and your ready to go.
Manfrotto head:
Manfrotto head:
ooohh this looks very promising!! thanks for the info :)
Charles:
I have had a Gitzo G1560 treking monopod for a number of years. I used it with an M6 when hiking in the mountains. It has a small ball head under the grip for use with a smaller camera like the M8.
Gitzo SA | le choix des professionels
thank you robsteve,
how easy is the monopod to extend and retract from your personal experience? i really like the slim shape of this monopod. it looks just like a hiking stick
thank you
thank you robsteve,
thank you
It is about the size of a hiking stick/ski pole. It is an internal twist lock. You turn it half a turn to lock it/ unlock it.
Robert
Heres another vote for the Gitzo walking pole. I've had one for several years and I really like it. So much less cumbersome than a full-blown monopod.
It's no more difficult to extend/retract than an equivalent leki (or similar) walking pole, provided you don't over-tighten it.
All the best,
I use a Velbon UP-4000 which is in three telescoping sections that drop down with a one-hand compression lock that is very handy. See Velbon | UP-4000 Unipod 4-Section | UP4000 | B&H Photo Video
You should have a ball head on top of it; I use a cheap, compact Sunpak item that is a natural extension of the monopod in use. See Sunpak | Compact Ballhead | 620710 | B&H Photo Video
It is a good combination under the M8.
Philip Kozloff
Manfrotto head:
I've a similar setup as Hank's... but use a Manfrotto 676B... In the pic quoted above(from Really Right Stuff) is the RSS B2 Pro clamp. RRS stongly recommends the tilt-swivel head over ball-head, and so would I. I've got a RRS BP-CS plate more or less permanently attached to the M8(great coverage over the lightweight baseplate and access to the baseplate release... and gives the option for alternate strap setup ala the 3-lug M5... works well)... in sum: Manfrotto/Bogen 676B monopod, Manfrotto 3232 tilt-swivel head, RRS B2 Pro clamp and RRS BP-CS is used hiking, etc.
hth+rgds,
Dave
334B
685B
thanks again ;)
I'm pretty happy of my M8 with the following set, light weight, cheap, easily operable.
http://www.manfrotto.com/Jahia/site/manfrotto/cache/offonce/lang/en/pid/2362?livid=107|117&idx=119
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/2376?livid=107|117&idx=118
regards
marcello
