Leica 28 Elmarit
fishdrummer
rather than add to the other informative post. Can someone tell me how my elmarit (2.8), 28 lens rates? It was made in canada during the mid 60's w/serial 20,62368. It has the a protruding lend barrel. I bought it seven years ago for about six hundred bucks.
a few questions - do i need to code it ? where would I find a lens hood for it - not sure which one it needs?
thanks again folks
you have a 1st vers 28/2.8. If you are planning on using it on the M8 - it won't meter. Nor will it meter on any M camera with a built in meter.
I'm not sure theres much point in coding or using it on the M8. lens hood is: 12501
bummer. thanks
Not a real bummer, be carefull .... you are probably sitting on gold ... if you happen to own a minty 9 elements first series 28 Elmarit ....the mint in box versions run for over Euro 2000 on the collectors market here in Europe .... :eek:
Look here .... Schouten Select Cameras & Accessories!
This guy is expensive .. but he is very reliable and the stuff he sells is first grade .... he sure knows the prices on 2nd hand/ collectors market!
Here you go:
thanks again folks
Whatever you do - do not modify this lens in any way. You indeed have the rare and much sought after 1st version. Serial number range for this lens was from 2 061 501 - 2 533 880 while the 2nd version (which does not look very different) started from 2 314 801.
This lens will reach $2000 or more on the used marked, so if you sell it you could get a new 2.8/28 ASPH which optically is much better but has no value as a collection piece (assuming you are only a user, not a collector).
[quote name= where would I find a lens hood for it - not sure which one it needs?
[/quote]
By the way, the lens hood is 12501, which is the same one as for the 3.4/21 Super-Angulon.
There is one out on e-Bay now but the price is on the high side:
Leica Lens Shade 12501 for 3,4/21mm boxed - (eBay item 280159803373 end time Oct-14-07 08:01:43 PDT)
I also checked KevinCameras and he has several in stock.
With a little patience, you will find it on eBay for about $100 - 150, depending on condition.
thanks very much for all the information.
