1 hour ago, Paul Heiney said:
I am enjoying my new D LUX 7, but NOT the strap which is a real fiddle to attach.  Very small split rings - finger ends bleeding, pen knife and pliers needed. Crazy. And it's too short!    How can you design genius cameras and provide lousy straps like these?
Paul, welcome! Have you considered a wrist strap? I find that solution better for my older version D Lux. Deft use of my penknife blade eases fitting a split ring. But a wrist strap has a simple loop to attach. There are alternatives.
  • 3 weeks later...
  • 4 months later...
My problem with the Leica Strap is it’s impossible to remove.  I always have a “quick release” mechanism on my camera strap ‘cause I like to be able to take it off easily.
I made a simple modification to make the Leica strap work.  It required two inexpensive purchases: two micro carabiners, and some super small split rings (because the strap connection on the camera is too small a diameter for any carabiner to slide through).
I got the carabiners at REI, and I bought the least number of split rings I could from Amazon… I only needed two, but I have 100, well…now 98..
  • 3 weeks later...
