gmaurizio Posted September 22, 2007 Share #1 Posted September 22, 2007 Advertisement (gone after registration) Hi all! I am using a B+W 52mm UV/IR filter with my CV 35mm F1.2. The problem is that, with that filter, I can not use the hood. Does someone know which filter brand should I use to be able to insert the hood? Thanks for your help. Link to post Share on other sites More sharing options...
Advertisement Posted September 22, 2007 Posted September 22, 2007 Hi gmaurizio, Take a look here CV 35mm F1.2 Nokton Filter. I'm sure you'll find what you were looking for!
ArtZ Posted September 22, 2007 Share #2 Posted September 22, 2007 Hi all!I am using a B+W 52mm UV/IR filter with my CV 35mm F1.2. The problem is that, with that filter, I can not use the hood. Does someone know which filter brand should I use to be able to insert the hood? Thanks for your help. I use a Nikon 52mm model LC-52 lens cap. (but I have scratched the Nikon logo on it!). Link to post Share on other sites More sharing options...
gmaurizio Posted September 22, 2007 Author Share #3 Posted September 22, 2007 Thanks Manuel, but my problem is which filter (UV/IR) will allow me to inset the hood... I can use the cap provided with the B+W filter, but no hood! And the hood keeps reflections away, specially in theater shots. Link to post Share on other sites More sharing options...
ArtZ Posted September 22, 2007 Share #4 Posted September 22, 2007 Thanks Manuel, but my problem is which filter (UV/IR) will allow me to inset the hood... I can use the cap provided with the B+W filter, but no hood! And the hood keeps reflections away, specially in theater shots. Oups! I bought the Vented Hood LH-3. I haven't tried with the original cap. Wait a minute... Link to post Share on other sites More sharing options...
ArtZ Posted September 22, 2007 Share #5 Posted September 22, 2007 My B+W UV/IR Silver cut 52mm #486 works fine with both hoods (normal and vented). Just tested. Cheers Added: In fact, you need the Nikon lens cap only when you use the vented hood LH-3 Link to post Share on other sites More sharing options...
stunsworth Posted September 22, 2007 Share #6 Posted September 22, 2007 If the filter has a hood then it's probably one on the B+W slimline ones. These are wider than the standard filters, hence why the lens hood won't fit over it. Exchange the filter for a non-slim one and you should be ok. I had exactly the same problem with my 24mm Elmarit. Link to post Share on other sites More sharing options...
gmaurizio Posted September 22, 2007 Author Share #7 Posted September 22, 2007 Advertisement (gone after registration) If the filter has a hood then it's probably one on the B+W slimline ones. These are wider than the standard filters, hence why the filter won't fit over it. Exchange the filter for a non-slim one and you should be ok. I had exactly the same problem with my 24mm Elmarit. Steve, you are absolutely right! Thanks... Link to post Share on other sites More sharing options...
gmaurizio Posted September 22, 2007 Author Share #8 Posted September 22, 2007 My B+W UV/IR Silver cut 52mm #486 works fine with both hoods (normal and vented). Just tested. Cheers Added: In fact, you need the Nikon lens cap only when you use the vented hood LH-3 Thanks Manuel, Steve just hit the answer. I have the slim filter and it is larger than the barrel, therefore I can not clip the Hood. The regular (non-slim) version should do the trick. Link to post Share on other sites More sharing options...
ArtZ Posted September 22, 2007 Share #9 Posted September 22, 2007 If the filter has a hood then it's probably one on the B+W slimline ones. These are wider than the standard filters, hence why the filter won't fit over it. Exchange the filter for a non-slim one and you should be ok. I had exactly the same problem with my 24mm Elmarit. My filter is a normal one. No problem. Here is the B+W reference (as written in the box) 52 DIGI. PRO UV/IR-CUT CHROM 486 19758 Link to post Share on other sites More sharing options...
jeffwros Posted October 2, 2007 Share #10 Posted October 2, 2007 Does the lack of lens coding on the 35mm f/1.2 effect the performance on the M8 or create any issues with the images with the B+W filter? Link to post Share on other sites More sharing options...
dseelig Posted October 2, 2007 Share #11 Posted October 2, 2007 B &w makes several diff 52 uv ir filters at least one has a front screw in that you can use the voigt hood on call popflash they will be able to help David Link to post Share on other sites More sharing options...
bradreiman Posted October 2, 2007 Share #12 Posted October 2, 2007 Does the lack of lens coding on the 35mm f/1.2 effect the performance on the M8 or create any issues with the images with the B+W filter? i use this lens uncoded with ir filter and have really nice results. of course my 35/1.2 is not "working properly" at the moment, the lens barrell has alot of play and front-focusses drastically so i have to have it serviced...b Link to post Share on other sites More sharing options...
cliffordjim Posted October 3, 2007 Share #13 Posted October 3, 2007 Yes Manuel you are right... the lens is awesome... I use it with the B+W filter (non-slimline) and I have been shooting it mostly at 1.2 and couldn't be happier... I am a Noctilux addict but the M8 crop factor has relegated that lens almost strictly to portrait duty. The Nokton 35 1.2 is poetry in motion... here are 3 examples from a wedding 2 days ago... the last one is with flash... yup flash at 1.2 (thanks to Jamie for his advice on this) During the reception I slapped a Nikon SB25 flash on the M8 and set it on Manual at 1/64 power (the lowest setting possible) with the diffuser in place and the flash head straight up with built in flashcard in the up position... it works better than I had hoped ... and so subtle it's hard to tell there is a flash at all when it fires... helps with shadows on faces when it is really dark... I think the batteries will last for 5 years at this power setting!! Link to post Share on other sites More sharing options...
