Dopaco Posted October 11, 2022 Share #1 Posted October 11, 2022 Advertisement (gone after registration) If yes, what FLASH did you use? In the TL2 manual they recommend the Leica SF 40, SF 64, SF58 system flashes. Other Leica system flash devices, except Leica SF 20. Information on this is appreciated... Link to post Share on other sites More sharing options...
Advertisement Posted October 11, 2022 Posted October 11, 2022 Hi Dopaco, Take a look here Has anyone tried a Flash with CL or TL2?.. . I'm sure you'll find what you were looking for!
Guytou Posted October 11, 2022 Share #2 Posted October 11, 2022 (edited) Bonjour, Les mêmes recommandations figurent dans le manuel CL. J'ai un CL et j'ai récemment acheté un SF 24 d. Je me suis également procuré un câble d'extension Nikon SC-28 qui conserve la mesure TTL. L'ensemble fonctionne parfaitement. Guytou Edited October 11, 2022 by Guytou Link to post Share on other sites More sharing options...
Guytou Posted October 11, 2022 Share #3 Posted October 11, 2022 Sorry, in english... The same recommendations appear in the CL manual. I have a CL and recently bought an SF 24 d. I also got myself a Nikon SC-28 extension cable which retains the TTL metering. The set works perfectly. Guytou Link to post Share on other sites More sharing options...
kodachrome Posted October 26, 2022 Share #4 Posted October 26, 2022 Leica SF 40 is a good size relation to the CL body. The SF24 is underpowered and recycle times with only 2 AAA batteries. The SF40 has four AA in its compact size, its also has tactile manual controls. The SF 64 and SF58 do not and are rather large compared to the body. The SF60 is similar in size to the SF40 with dials and has the advantage of the being wireless with the SF C1 unit. Link to post Share on other sites More sharing options...
Guytou Posted October 26, 2022 Share #5 Posted October 26, 2022 2 hours ago, kodachrome said: Leica SF 40 is a good size relation to the CL body. The SF24 is underpowered and recycle times with only 2 AAA batteries. The SF40 has four AA in its compact size, its also has tactile manual controls. The SF 64 and SF58 do not and are rather large compared to the body. The SF60 is similar in size to the SF40 with dials and has the advantage of the being wireless with the SF C1 unit. No, the SF 24 D does not use AAA batteries but two small CR123 lithium batteries. These batteries have a rather comfortable charging time and are therefore interesting. Guytou Link to post Share on other sites More sharing options...
kodachrome Posted October 27, 2022 Share #6 Posted October 27, 2022 21 hours ago, Guytou said: No, the SF 24 D does not use AAA batteries but two small CR123 lithium batteries. These batteries have a rather comfortable charging time and are therefore interesting. Guytou SORRY FOR THE TYPO SF 26 USES AAA BATTERIESThe SF26 is underpowered and recycle times with only 2 AAA batteries Link to post Share on other sites More sharing options...
Dopaco Posted October 27, 2022 Author Share #7 Posted October 27, 2022 (edited) Advertisement (gone after registration) El hilo está duplicado, el real se sigue aquí: Edited October 27, 2022 by Dopaco Link to post Share on other sites More sharing options...
