1 minute ago, Matlock said:
Interesting but the cameras shown in the video haven't been made for a number of years. When was this film made?
No idea.  But you can see an M7 and MP being made.  The M7 was discontinued in 2018.
The M7, MP and R9 were all introduced in 2002 and I suspect this video is from about then. All Leica Film Ms (and most other Ms) are made in Portugal now.
I think this may have been discussed one or two times before…. If only the forum had some sort of search feature. 🤔
http://www.fdtimes.com/wp-content/uploads/2017/02/80FDTimes-LEICA-PortugalFactoryTour.pdf (this document should be pinned or at least every M owner or potential owner should be made to read it before getting their camera)
Quote
Leica Portugal is where most of the work begins on Leica M and Leica S cameras: crafting raw blocks of aluminum with the latest CNC equipment into camera bodies, meticulously hand polishing the surfaces un- til they are silky smooth, and inspecting the work every step of the way.
Oh, and to reply to what the other participant wrote in yet another thread…
Quote
Labor costs in Portugal are among the lowest in Western Europe
I believe to be able to stamp “Made in Germany” on the bodies, what they call final assembly is done at the factory in Germany. I’m guessing that means putting on the bottom plate, fixing to top plate, an inspection, good clean up and generally made ready for an unboxing video.
12 minutes ago, ianman said:
I believe to be able to stamp “Made in Germany” on the bodies, what they call final assembly is done at the factory in Germany..
According to this site
German courts have ruled that products with this label must at least be assembled in Germany. And more than half of the parts used should also come from Germany.
I'm quite sure that Leica follows the rules required to use the 'Made in Germany' stamp, so at least half the parts in M cameras must be made in Germany.
That doesn't explain how some Leica lenses are made in Portugal yet are labelled Made in Germany. Some were re labelled Made in Portugal to get round the Trump restrictions.
That may be so. The article was written in 2017 IIRC, this court decision may have been made later. But tbh, I personally couldn’t care less where my camera was built. It’s solid, works perfectly and suits me fine. The rest is totally irrelevant.
If Leica is following the rules laid out by the German courts for using the 'Made in Germany' label (and I have to assume that they are or they'd run afoul of the German courts), then at least half the parts used in Leica lenses so branded must be made in Germany - regardless of which factory or factories are involved in the lens's manufacture.
Re: 'Made in Portugal' on lenses, I have no idea what the rules are for using such branding - if there are any.  But, again, I have to assume that Leica followed the rules when using the branding on their lenses in order to get around the Trump-era tariffs on German lenses.  So it's quite possible that the lenses satisfied the requirements of both the 'Made in Portugal' and 'Made in Germany' labels and some were simply branded 'Made in Portugal' to avoid the US tariffs.
If Leica choose to sell them as Made in Germany, the lenses will be assembled in Germany to comply with the legislation.
If Leica want to get around trade restrictions in the US, then they can just complete the lenses in Portugal, and label them as such.
Same lens, same quality
+1 I don't care where the bits of my cameras and lenses are actually manufactured, assembled, boxed, etc.  The ones I own look great, feel great , work great and put a smile on my face every time I use them.
My M7 has a light leak
  • Haha 4
That may be so Andy but it doesn't explain how most M cameras are now made in Portugal but labelled "Made in Germany". As has been stated before, the "Made in ....." usually only applies to final inspection and boxing in most EU countries (and elsewhere). Most French companies get round any ambiguity by simply labelling products "France". It's a fascinating subject but doesn't really have any bearing on the quality of Leica products thankfully.
Here is its replacement:
They are not made 100% in Portugal.
Take a factory visit and they will explain everything. Sub-assemblies come from Portugal and are put together in Wetzlar.
Thanks Andy, however the article in Film & Digital Times would seem to indicate otherwise and shows cameras complete except for top and bottom plates (I can accept that final assembly in Germany would cover that but that is pushing the term sub-assemblies a bit far 🙂 ) however it also shows complete lenses and that cannot be explained. Interesting.
I did the tour some years ago (2010 IIRC). At that time the technicians were attaching the top and bottom plates and preparing them for shipment. Perhaps more was being done beyond what they showed visitors.
Production of lenses was however much more involved with the grinding machines working away, full hand assembly and rigorous testing of the lenses by the technicians. I think I remember them saying that the metal parts were manufactured at the Porto plant. Of course, since then they may have changed things, the article mentions an enlargement of the Porto factory in 2013. And the factory in Germany has been moved since I went to Solms.
