IzelPhotography Posted August 25, 2022 Share #1 Posted August 25, 2022 Advertisement (gone after registration) I've only had the M11 a couple of days but I hadn't realised that tethering was available in C1 Pro 22. Naturally you cannot change aperture but full control of everything else, ISO, speed, metering, remote trigger etc as well as live view. A nice bonus to be able to use it in the studio and shoot straight into C1. So far it seems to work with the same USB C cables I use with the Sony system into a MacBook M1 Max. Might make a wooden grip to help shield/support the USB c plug when not shooting from a Manfrotto Magic Arm. 1 Quote Link to post Share on other sites More sharing options...
Advertisement Posted August 25, 2022 Posted August 25, 2022 Hi IzelPhotography, Take a look here Capture One Pro M11 Tethering. I'm sure you'll find what you were looking for!
IzelPhotography Posted August 25, 2022 Author Share #2 Posted August 25, 2022 Just a quick follow up. Capture One Pro website is still reporting the Leica M11 as not being supported for Tethering or Live View. I tried a couple of cables and it doesn't work with all. Most reliable with a 2m thunderbolt 3 cable. Setup. Mac OS, C1 Pro 22, Leica M11 USB set to PTP. Quote Link to post Share on other sites More sharing options...
Photoworks Posted August 25, 2022 Share #3 Posted August 25, 2022 Yes, the later firmware added it. but not supported at this point. This is going to get real exiting when the tether with iPad in capture one comes out next month. Quote Link to post Share on other sites More sharing options...
IzelPhotography Posted August 25, 2022 Author Share #4 Posted August 25, 2022 Interesting. I'm just finding my feet with the M11, main system is a Sony A9 etc plus the Leica Q-P which the M11 replaces. As it stands, what's the best way to transfer images from the internal memory to a MacBook? The cable works well with my iPhone but my iPad has usb c connection. Quote Link to post Share on other sites More sharing options...
Photoworks Posted August 25, 2022 Share #5 Posted August 25, 2022 10 minutes ago, IzelPhotography said: Interesting. I'm just finding my feet with the M11, main system is a Sony A9 etc plus the Leica Q-P which the M11 replaces. As it stands, what's the best way to transfer images from the internal memory to a MacBook? The cable works well with my iPhone but my iPad has usb c connection. I think they are still working out the bugs... The best speed for downloading right now is true WIFI, it was different before the FOTOS app update where the cable was better. It is still a mystery with cables work for the iPad, it is still a limitation of the Fotos app. For now the cable from the iPad Pro works. and I found some USB-C 2.0 work in 5 meter 1 Quote Link to post Share on other sites More sharing options...
sdk Posted September 26, 2022 Share #6 Posted September 26, 2022 On 8/25/2022 at 9:28 AM, Photoworks said: I think they are still working out the bugs... The best speed for downloading right now is true WIFI, it was different before the FOTOS app update where the cable was better. It is still a mystery with cables work for the iPad, it is still a limitation of the Fotos app. For now the cable from the iPad Pro works. and I found some USB-C 2.0 work in 5 meter I have been trying to tether my M11 to my iPad Air for critical focusing and tripping the shutter using Fotos. I will probably use for capturing negatives to digital with my 100mm Makro Planar, a Nikon F-M mount adapter, and a lightbox and copy stand. I would then use the card reader and Lightroom/PS on my MacPro to process negatives captures into positive files to print. So far I have not got a cable to work, only WiFi. Do you mean to say USB 2.0 standard USB C cables not Gen 2 of USB 3.1 standard USB C cables? The older standard works better? Weird. Quote Link to post Share on other sites More sharing options...
Hanno Posted September 26, 2022 Share #7 Posted September 26, 2022 Advertisement (gone after registration) As FYI you can now tether the M11 to an iPad with the Capture One app. It works flawlessly but bear in mind the Capture One app has limited features for time being so it is really for tethering in my view. Quote Link to post Share on other sites More sharing options...
Photoworks Posted September 26, 2022 Share #8 Posted September 26, 2022 Capture One for iPad works well with Leica M11 and Leica SL2 with USB-C cable. There are still some bugs, but a good start. It is strange that almost all cables work with Capture one for iPad, while FOTOS app does only works with very few cables. 1 Quote Link to post Share on other sites More sharing options...
sdk Posted September 27, 2022 Share #9 Posted September 27, 2022 Thanks @Hanno and @Photoworks. I am going to try some different USB-C and Thunderbolt 3 cables today. Maybe one will work, and then that can be my tethering cable. I really just want to control the camera, not process on the iPad. Quote Link to post Share on other sites More sharing options...
Photoworks Posted September 27, 2022 Share #10 Posted September 27, 2022 1 minute ago, sdk said: Thanks @Hanno and @Photoworks. I am going to try some different USB-C and Thunderbolt 3 cables today. Maybe one will work, and then that can be my tethering cable. I really just want to control the camera, not process on the iPad. There are not options to Control the camera in Capture one for iPad . only a capture button at this point, maybe in the future. I only capture to iPad on location to see the image larges and see how much I can recover. Processing will be done later on the computer. Focus app is the only one that can change exposure and shoot. and for that USB-C 2.0 cable works on a iPad Pro with usb-c port. If you have the IPAD with lighting port you have to use the provided Leica cable for data transfer. Quote Link to post Share on other sites More sharing options...
