parkerfoster Posted July 21, 2022 Share #1 Posted July 21, 2022 Advertisement (gone after registration) I'm currently a SL 601 owner and have been tempted to go to the SL2s for the USB-c powered options since I've been shooting more video and I'm used to cameras powering off v lock or gold mount or having a dummy battery to p-tap. I can't find really any article or discussion about people who are rigging up their SL2-s and powering it off a v lock or gold mount. Does anyone do this and what has the experience been like? Link to post Share on other sites More sharing options...
Advertisement Posted July 21, 2022 Posted July 21, 2022 Hi parkerfoster, Take a look here Leica SL2-S Powered off V Mount battery . I'm sure you'll find what you were looking for!
BernardC Posted July 21, 2022 Share #2 Posted July 21, 2022 You'll want to have a look at this thread: The short answer is that you need a USB-PD compliant power supply, which isn't the case with most V-Lock batteries that provide plain 5v 2A USB. The thread mentions some models that work. Unfortunately, not all power supplies that claim to support USB-PD work with all devices that make the same claim. It's not just a Leica issue, you'll run into the same problems with smartphones and laptops. 1 1 Link to post Share on other sites More sharing options...
Pelu2010 Posted July 25, 2022 Share #3 Posted July 25, 2022 Hey , I am doing just that. Using a V-mount battery to power the sl2s. I use these Batteries: https://bundlestar.de/akkus/v-mount/v-mount-akkus/181/patona-premium-v-mount-akku-bp-95w?gclid=Cj0KCQjw_viWBhD8ARIsAH1mCd46e_RPbXLk4WmH05qQzqXZssO_63TEkduXDUnvuYSxOKVNBPp_m6waAlcsEALw_wcB And there is also the option to do this : d-tap to USB-C https://www.mediatec.de/objektive/zubehoer/tilta-micro-usb-to-dtap-cable-for-nucleus-n?gclid=Cj0KCQjw_viWBhD8ARIsAH1mCd6Lvybl4aAfvz-j7aFWYgHjA8id9Bz0_W8pesemoCKN8TE4Ltulse0aAkiMEALw_wcB the other option I recommend are these Anker batteries : https://www.amazon.de/Anker-PowerCore-10000mAh-Powerbank-kompatibel-Black/dp/B091TSFZ74/ref=sr_1_3?__mk_de_DE=ÅMÅŽÕÑ&crid=3KZ3BJ8FP3ECJ&keywords=ANKER+PowerCore+II+10000mAh+Power&qid=1658747138&sprefix=anker+powercore+ii+10000mah+power%2Caps%2C105&sr=8-3 Excellent for the power, when you are on the road. And since I use Anker , I never had any issue any more. The V mount I use mostly when I use a slider and I need more power. Kind regards Peter 2 1 Link to post Share on other sites More sharing options...
Pelu2010 Posted July 25, 2022 Share #4 Posted July 25, 2022 2 minutes ago, Pelu2010 said: Hey , I am doing just that. Using a V-mount battery to power the sl2s. I use these Batteries: https://bundlestar.de/akkus/v-mount/v-mount-akkus/181/patona-premium-v-mount-akku-bp-95w?gclid=Cj0KCQjw_viWBhD8ARIsAH1mCd46e_RPbXLk4WmH05qQzqXZssO_63TEkduXDUnvuYSxOKVNBPp_m6waAlcsEALw_wcB And there is also the option to do this : d-tap to USB-C https://www.mediatec.de/objektive/zubehoer/tilta-micro-usb-to-dtap-cable-for-nucleus-n?gclid=Cj0KCQjw_viWBhD8ARIsAH1mCd6Lvybl4aAfvz-j7aFWYgHjA8id9Bz0_W8pesemoCKN8TE4Ltulse0aAkiMEALw_wcB the other option I recommend are these Anker batteries : https://www.amazon.de/Anker-PowerCore-10000mAh-Powerbank-kompatibel-Black/dp/B091TSFZ74/ref=sr_1_3?__mk_de_DE=ÅMÅŽÕÑ&crid=3KZ3BJ8FP3ECJ&keywords=ANKER+PowerCore+II+10000mAh+Power&qid=1658747138&sprefix=anker+powercore+ii+10000mah+power%2Caps%2C105&sr=8-3 Excellent for the power, when you are on the road. And since I use Anker , I never had any issue any more. The V mount I use mostly when I use a slider and I need more power. Kind regards Peter This is the USB-C Cable https://www.amazon.de/Stromkabel-Blackmagic-Konverter-Alvins-Cables/dp/B09Q53XB3V/ref=asc_df_B09Q53XB3V/?tag=googshopde-21&linkCode=df0&hvadid=579697758434&hvpos=&hvnetw=g&hvrand=16608708999212812973&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9061054&hvtargid=pla-1641610749496&th=1 1 Link to post Share on other sites More sharing options...
parkerfoster Posted July 26, 2022 Author Share #5 Posted July 26, 2022 Thanks so much! Link to post Share on other sites More sharing options...
matted Posted December 20, 2022 Share #6 Posted December 20, 2022 I saw these Smallrig v-mount batteries being reviewed on some YouTube channel and bought one (I bought the 50 WH version) and thought I hit pay dirt… a small form factor v-mount battery that has D-tap, USB-A, USB-C PD. Cool! Unfortunately, the battery does not seem to be compatible with whatever version of PD Leica has implemented on the SL2-s… the battery only ever shows “5v” on the USB-C outlet. I just confirmed it can deliver 20v to my MacBook Pro, with enough watts to run it and charge the battery up to a certain point… if I run some intensive applications the laptop stops charging it’s battery but that is still impressive either way. Obviously the battery is capable of delivering whatever the camera needs (unsure if it is 9v or 12v) but something is breaking down in communication. I tried a few other USB-C PD devices I have and they are hit and miss… my Milwaukee MIL-2846-20 M18 TOP-OFF 175W Power Supply (which can also run my MacBook Pro with no issues) also gets the “device does not support enough power” error message on the SL2-S. Ironically, my Acebeam 18650 batteries (they have an integrated USB-C port) which do not seem to conform to USB-C standards when being charged, however they work just fine to power the SL2-S. It is disappointing that the Smallrig batteries do not work for powering the SL2-S but they are still pretty great…. They are still a perfect solution for powering the rest of my rig (Tilta focus servo, SmallHD monitor or Odyssey 7q recorder), and having the ports integrated is great. The battery can even be charged via USB-C which is super convenient for travel. 1 Link to post Share on other sites More sharing options...
Genoweffa Posted January 22, 2023 Share #7 Posted January 22, 2023 Advertisement (gone after registration) Any users of Anker PD's?...which one I should get 10000mAh, 20000mAh?...any other suggestions will be appreciated (SL2) Link to post Share on other sites More sharing options...
Photoworks Posted January 23, 2023 Share #8 Posted January 23, 2023 https://www.amazon.com/gp/product/B07PXMF52C/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Anker PowerCore 10000 PD Redux, 10000mAh Portable Charger USB-C Power Delivery (18W) this is 2 years old model, Anker keep changing fast, but it works well for me on SL2 Link to post Share on other sites More sharing options...
Daniela Stephan Posted December 13, 2023 Share #9 Posted December 13, 2023 Hi everyone. I’ve been looking for a battery mount for the SL2. Is it the same as the SL2S? And if i’m shooting all day video and need extra power what is the best option? thank you Link to post Share on other sites More sharing options...
Photoworks Posted December 18, 2023 Share #10 Posted December 18, 2023 On 12/13/2023 at 3:48 PM, Daniela Stephan said: Hi everyone. I’ve been looking for a battery mount for the SL2. Is it the same as the SL2S? And if i’m shooting all day video and need extra power what is the best option? thank you what is a battery mount? grip? Link to post Share on other sites More sharing options...
