Izzy Posted July 18, 2022 Share #1 Posted July 18, 2022 Advertisement (gone after registration) Hi there. I’ve set my M10 to Aperture Priority. ISO Setup is set to Max Auto ISO 3200. Max exposure time 1/f. 28 Elmarit lens shot wide open. However the resulting image was ISO800 (1/60) instead of a higher iso. Is there a reason why ISO 1600 was not used instead. Am I missing something ? Thanks in advance. Rgds Izzy Link to post Share on other sites More sharing options...
Advertisement Posted July 18, 2022 Posted July 18, 2022 Hi Izzy, Take a look here Leica M10 Auto ISO question. I'm sure you'll find what you were looking for!
Izzy Posted July 18, 2022 Author Share #2 Posted July 18, 2022 9 minutes ago, Al Brown said: It seems it had enough light for the move, going closer towards your desired setting. Elmarit's f/2.8 at 1/60 and ISO800 means that Leica was holding the fine line between not unnecessarily raising the ISO and still balancing the handheldability with as short of a shutter speed as possible. If ISO1600 was used instead, the shutter speed would be 1/125, but that is already a departure from your 1/f setting. It's that simple. Thanks Al. Link to post Share on other sites More sharing options...
Anakronox Posted July 19, 2022 Share #3 Posted July 19, 2022 With my digital Ms, I never let the shutter speed be controlled by the camera. I prefer to let it decide the ISO automatically, however. My M10 I capped at 6400 and M10M 32,000. I suppose because of this I don’t worry about blurry shots because the shutter chosen was too slow. 1 Link to post Share on other sites More sharing options...
rramesh Posted July 21, 2022 Share #4 Posted July 21, 2022 (edited) Suggest you don't use Auto ISO on the dial. You can either set the dial to the ISO you want the camera to use, or set the dial to M and then use profiles to set a profile for your preferred ISOs. Say one for ISO 200, one for ISO 800, one for ISO 6400 or one for Auto ISO. You can use this with your preferred Max Exposure Time, or go full manual by rotating the speed dial to the speed of your choice. Edited July 21, 2022 by rramesh Link to post Share on other sites More sharing options...
