jwillyf Posted June 28, 2022 Share #1 Posted June 28, 2022 Advertisement (gone after registration) A drop of my M246 camera has disrupted the vertical alignment of the rangefinder. I believe a special tool is required, available on a well known auction site. If I were to buy one, how do I access the adjustment mechanism? Is it behind a screw sited just above the lens? Is it an easy fix? P.S. This originally posted in M Monochrom group Link to post Share on other sites More sharing options...
Advertisement Posted June 28, 2022 Posted June 28, 2022 Hi jwillyf, Take a look here Vertical alignment. I'm sure you'll find what you were looking for!
Patrick1955 Posted June 28, 2022 Share #2 Posted June 28, 2022 I can only speak from personal experience for the M10, but it is indeed an easy adjustment to make, although a little nerve-racking at first when taking off the Leica red dot. Once the adjustment screw was exposed it just took small movements with a 2mm Allen key (and some patience) to correct. No special tool required. There are a number of step by step instruction on this forum. The idea of returning my M to Leica (with all the cost and delays etc) for what is a very simple adjustment now seems silly. 1 Link to post Share on other sites More sharing options...
jwillyf Posted June 29, 2022 Author Share #3 Posted June 29, 2022 Thanks for the reply. Glad to hear a traditional Allen key would do the job. However, there is no red dot on my M246 so that’s why I wondered if the adjustment mechanism resided behind the black screw head above the lens? Link to post Share on other sites More sharing options...
jwillyf Posted June 29, 2022 Author Share #4 Posted June 29, 2022 Patrick, Having done some more research on Youtube as you suggested, it seems the adjustment using a 2 mm Allen key is for correcting the horizontal alignment whereas the adjustment of vertical alignment does require a specialised tool. Link to post Share on other sites More sharing options...
Patrick1955 Posted June 30, 2022 Share #5 Posted June 30, 2022 The black screw-head above the lens is a blank covering the access hole for adjusting VERTICAL alignment. It is the same hole that is covered by the Rod Dot on my M10, and the same screw-head blank as covers the hole on the M10-P. I am surprised the M246 and M240 requires a special tool but maybe I just lucked out with the M10. As it is easy and non destructive to remove the screw-head blank - may I suggest you just take a look. Here is a youtube showing an M10 undergoing the procedure: Horizontal alignment is adjusted by using the allen key on the underside of the roller that is at the end of the focus cam that is in contact with the lens. Move the cam and watch the focus patch move horizontally in the viewfinder. The alignment adjustment there is for the horizontal movement. Here is a video from Youtube showing the horizontal adjustment. I 2 1 Link to post Share on other sites More sharing options...
jwillyf Posted June 30, 2022 Author Share #6 Posted June 30, 2022 Thanks, Patrick. I am wary about tackling a job such as this ‘blind’ with my beloved M246. I will remove the screw and inspect. Rangefinder calibration with a repairer I have used before here in the UK costs £122, so worth investigating a DIY approach. I will keep you posted. 1 Link to post Share on other sites More sharing options...
jwillyf Posted July 2, 2022 Author Share #7 Posted July 2, 2022 Advertisement (gone after registration) Hi, Patrick. I removed the screw cap and gently inserted a 2mm hex key. It engaged and a few tiny incremental rotations one way and then the other had the vertical alignment sorted within a minute. Thanks so much for your interest and help. Link to post Share on other sites More sharing options...
Patrick1955 Posted July 3, 2022 Share #8 Posted July 3, 2022 My absolute pleasure and I am so pleased you trusted your hand at the task. I like dispelling the myths surrounding Leica being so fragile that all matters of routine maintenance must be addressed in Wetzlar (or DAG if in the US). Regards Link to post Share on other sites More sharing options...
FDS Posted July 13, 2022 Share #9 Posted July 13, 2022 Many thanks for this thread and especially to 'Patrick1955'! (If that's a birth year then my DOB is 20.12.1955.) I just had the vertical RF adjustment 'go off' on my M11. In my case, a 1.5mm Allen key did the job easily (rather than a 2mm). Link to post Share on other sites More sharing options...
Patrick1955 Posted July 14, 2022 Share #10 Posted July 14, 2022 My pleasure FDS - we older folk need to help you youngsters (I am 4 months older, almost exactly). 1 Link to post Share on other sites More sharing options...
jwillyf Posted July 14, 2022 Author Share #11 Posted July 14, 2022 My birth year is 1946! 1 Link to post Share on other sites More sharing options...
FDS Posted July 14, 2022 Share #12 Posted July 14, 2022 I am indebted to my distinguished elders! Link to post Share on other sites More sharing options...
andybiggs Posted October 1 Share #13 Posted October 1 Managed to make an adjustment on my m240 the red dot is held in place with “double sided tape” using finger nails I twisted back and forth and then used the point of a scalpel to lift it. You might loose a touch of the red paint. it only needs a slightest of movement with the Allen key to make an adjustment. Replaced the dot ok but i do use black tape to cover it anyway. i know many users check the infinity setting but feel taking a photo at around 8 feet at full aperture a good test. Link to post Share on other sites More sharing options...
