hirohhhh Posted May 27, 2022 Share #1 Â Posted May 27, 2022 (edited) Advertisement (gone after registration) Is there a way to use Leica flases off-camera connected with the Profoto Air Remote on the camera's hot shoe? I'd like to test SF64 flash off-camera and the only remote I have is Profoto, but I can't make it work. Edited May 27, 2022 by hirohhhh Link to post Share on other sites More sharing options...
Advertisement Posted May 27, 2022 Posted May 27, 2022 Hi hirohhhh, Take a look here Profoto Air Remote with Leica Flashes. I'm sure you'll find what you were looking for!
brembeck43 Posted May 27, 2022 Share #2 Â Posted May 27, 2022 no, that does not work 1 Link to post Share on other sites More sharing options...
Photoworks Posted May 27, 2022 Share #3 Â Posted May 27, 2022 SF64 is an older flash and it does not have wireless transmission. There is an optical sleeve mode. not sure if flashes when other flash go off or infrared. in any case you can use it indoors as a slave. If you just need to extend the reach you can use a TTL-Nikon extension cable on your hotshoe Link to post Share on other sites More sharing options...
hirohhhh Posted May 27, 2022 Author Share #4 Â Posted May 27, 2022 1 hour ago, Photoworks said: SF64 is an older flash and it does not have wireless transmission. There is an optical sleeve mode. not sure if flashes when other flash go off or infrared. in any case you can use it indoors as a slave. If you just need to extend the reach you can use a TTL-Nikon extension cable on your hotshoe Oh, is that what's hiding behind that cover with Leica logo!? This is new to me... and I happen to have this cable, so I'll give it a try now. Thanks! Link to post Share on other sites More sharing options...
hirohhhh Posted May 27, 2022 Author Share #5 Â Posted May 27, 2022 It works! I'll just have to get a shorter cable (mine is 5m), or new flash with wireless transmission. SF 20 should be working wirelessly, right? Link to post Share on other sites More sharing options...
Photoworks Posted May 28, 2022 Share #6  Posted May 28, 2022 Nikon SC-17 TTL Flash Extension Cord Look on eBay if you need TTL you need to use the Leica SF60 + SF C1 I use SFc1  + Nissin i60a with latest firmware, they work wirelessly in TTL. On the hotshoe it only manual mode. if you are using it in M mode you can use any other wireless system. Profoto, Godox, Elinchrom. Link to post Share on other sites More sharing options...
